Introduction: How to Make a Wooden Pipe
Wooden pipe has a unique taste at smoking, and for that in this instructable I will show you how to make a special one for yourself made out of simple materials and strong wood.
This wooden pipe was made in a professional way and carefully homemade.
For this gift you will need:
Materials:
- A thick piece of wood
- Stem of a pipe (that contains the filter)
- metal bowl
- optional: olive oil + white vinegar + lemon juice (that just to give dark color)
- ribbon for gifts
Tools:
- hand saw
- drill
- hand sander
- hole saw
Step 1: First This Is the Intial Design
Step 2: Find a Thick Piece of Wood
saw the piece of wood to the precise size of your pipe around 20/10 cm
Step 3: Cutting the Initial Size
cut the piece of wood to the initial size of the pipe to be ready to the next step
Step 4: Hole the Bowl
Using 29 mm hole saw and a drill make a hole in the center of the top side and be careful in this step to don't broke it
Step 5: Drill the Air Way
using a drill and a 6mm bit make the air way to the center of the bowl
Step 6: Sand It Carefully
After cutting it, sand using a hand sander the wood till you have that smooth touch
Step 7: Color the Wood
As you can see the difference between the two photos, in the last photo I brushes it with a natural mixture made up of olive oil and vinegar and lemon juice which give me that dark color
Step 8: Set Up the Stem and the Bowl
Step 9: Decorate the Pipe
Step 10: Test the Pipe
Step 11: Ready to Present !!
Step 12: Addition
Here I've added some beautiful wood pieces.
