Introduction: Homemade Xacto Knife
Step 1: Broken Hacksaw Blade
Tools needed:
Bench grinder/ Files
Wet stone/wet sandpaper
Coping saw
Materials:
Broken/used hacksaw blade/saws all blade
3/4 dowel
Rubber band/string line
Layout the profile of your choice on the blade,
I did my layout
with a led pencil, you can be more technical and add a piece of masking tape and grind the perimeter of your line.
Start your rough sharpening at the bench grinder right after you are finished with your profile.
Time to start sharpening with your wet stone,
Mine is a two sided 80/ 300 grit. You can use sand paper if you wish.
I end up polishing the sides to reduce friction.
Cut your 3/4 stock to the desired length and cut a slot with the coping saw at one end to receive the blade shank.
Wrap the cut end with a rubber band, I used a piece of an old inner tube.
All in all took about 20 minutes to do and the results are fantastic, I will be making a couple more more with different profiles.
