Introduction: Homemade Airbrush Stand
For making this stand you will need
1.Copper wire (3-4 mm in diameter) thicker is better,
2.appropriate plastic hose (or heat shrinkable tubing)
3.alu pipe 20 mm die (14 mm inside dia.)
4. Bolt 8 or 10 mm
5. 4 nut and 4 washers for the bolt you purchase
6. for base you can use 50 CD/DVD spindle or 12mm anchor and screw depends what type of base you choose
4. Bolt 8 or 10 mm
Step 1: Holders, and Shaft
Insert wire in hose. Than split wire in half.
Make the hose longer than wire; you don't want to end with scratched airbrush.
Make a loop in the middle of wire and than shape rest of the wire as seen on picture.
Loop in the middle of wire will be used to insert shaft (bolt), to hold both airbrushes.
Then hammer one side of alum tube until its flat.
In flatten part drill hole bigger than bolt you bought.
Use bolts and nuts to hold both holders.
I used isolation tape to cover aluminum - that way airbrush won't rub over aluminum.
All aluminum parts cut and file (ends can be sharp) so use Dremel to shape and file pipes an copper.
Step 2: Base
Stand is done.
You need to decide what type of base you need.
Use 50 CD/DVD spindle as a base. This base can be unstable, therefor I inseted 12 mm PVC anchor , that way stand can be bolted.
Step 3: Finished
Be carefull and first check which type of base works for you.
