Introduction: Homemade Bicycle Slick Tires.
This Instructable will explain how I made some slicks for one of my bikes. You can do the same, just remember to wear appropriate safety gear, (A glove and a breathing mask as a minimum, a plastic raincoat would also be recommended.)
Step 1: Tools and Equipment.
To do this you will need some type of directional sanding tool, by which I mean either a belt sander or an angle grinder with a sanding pad like I used. You will also need a straight and true front wheel that matches the tires you want to sand and a bike flipped upside down so you can use the forks as the wheel mount. Probably best to use a bike you don't care as much about as it will get messy as shown in the photo, the rubber does however easily hose off.
Step 2:
With the tire you want to sand mounted on the wheel and inflated to around 5psi below it's recommended maximum, (The air will expand and increase pressure as some heat is transferred to the air inside while sanding.) and also mounted on the bike fork, check it spins easily and true, if it doesn't you will end up with flat spots on your tire which will more than likely lead to sanding too much off and exposing the canvas in places.
Hold your sander in your dominant hand and with your other hand in a glove hold the wheel from spinning, start sanding each knob down to where it is almost even with the rest of the tire, working your way around the tire on one side. Once you have them all evenly close to the smooth portion, release a bit of pressure with your glove hand and allow the wheel to spin as you are sanding, you will find you can adjust the speed of the spin by varying the angle of the sanding disc and what portion of the disc touches the tire, with a bit of practice you will end up with something like the tires pictured here.
Step 3: Repeat for the Other Side.
Just as the title says, repeat for the other side and you will end up with a nice even slick for your bike just like the ones in these pictures.
The next step will give some pointers on which tires are best for making slicks and why.
Step 4: Which Tire Is Best?
I did a bit of experimenting with different tires to find what tires are the best for doing this, I even tried three identical tires but that were of different age and condition.
The three matching tires I had were all the same brand but 1 was brand new, never used and never been in the sun, 1 was slightly used but left in the sun for a year, and the last one was practically new but left in the sun for approximately four years.
The results were interesting considering these were all the same brand and model tire, the older and harder the tire was, the better the end result! The brand new one flexed it's rubber knobs so much as it was being sanded that it sanded through in places as you can see in the main photo for this step, the slightly older one was nice and even but ended up weighing less than the oldest one, indicating that more rubber was taken off it to achieve the smoothness required.
After doing those I went looking for the oldest and heaviest tire I had, which was the Kenda Comp pattern tire in the other 2 photos on this page, it was approximately 10 years old and had been left in the sun for most of it's life, the bike it came off was found at the back of a scrap metal yard where it had been for many years, It had no cracking on it but was really hard, the results of this tire were the best of all, really smooth and the most rubber thickness left when finished.
So the best tire to do this with is one that is harder, and possibly older...
Step 5: Clean Up!
Cleaning up the bike/fork/rim and tires is easy, just get out your garden hose and give them a good rinse, clothing is another matter, you can hose them off as best you can but put them in the wash by themselves or with a rag load, not with your best evening wear, I would even recommend doing an extra "no clothes" load after to ensure all the rubber dust is gone. Best bet would be to wear a throw away plastic raincoat and save yourself the hassle...
If you like this Instructable why not check out my other one here: https://www.instructables.com/id/Making-wide-bike-wheel-hubs-and-joining-them-to-ca/
The last 3 photos are from that Instructable...
Have fun and be safe!
LTJ.
3 People Made This Project!
- Yard Sale Dale made it!
- JrL8 made it!
- JrL8 made it!
48 Comments
9 years ago on Introduction
Thanks for your instructable! whats the deal with the GIANT sprocket on the tallbike?
did you make it yourself?
nireves1, agallagher4 and andrea biffi,
The sprocket on the minivelo is 120 tooth and was made for me by a guy in the U.S.A. he unfortunately does not make sprockets anymore though. The bike will end up with a 20 tooth BMX freewheel on the rear which will give it a 120 gear-inch ratio with the 20" slicks, that is a bit higher than most race bikes top out at, they tend to run 105-110 gear"
Anymore details you might want can be found here on the build thread:
http://www.ratrodbikes.com/forum/index.php?threads/winter-build-off-mini-velo-episode-13-aerobars-video.81029/
LTJ.
I have a 125 tooth aluminium sprocket on my 20" recumbent - made in Holland ;-)
125! Well you got me beat! That bike must fly!
It's 125 frontsprocket, 13/14/15/16/17/19/21 on the wheel.
So it really depends on which gear I choose. I have pedalled it close to 50 KM/h. Could go faster, but got a little scared......
Have you got any photos of it?
This is the model bike I have - It's a Flevobike.
Mine's a little more worn down, though. I use it every day to commute.
Cool bike!
And it rides pretty good too - you could build it yourself (a lot of people already have)
http://www.myvoice.nl/ligfiets/tekeningen.php
Takes some effort to learn to ride it (leaning to stear, use no hands) but after that it's really comfortable...
As an " old guy " with not much money in my early bike days, " we " improvised, invented and manufactured knock - off cool stuff for our bikes. Didn't have credit cards, a paper route didn't pay much, etc. but it was fun seeing who could come up with a new, cool idea for a bike.
9 years ago
Forget the slicks what's the story on that bike?
Which one?
The big one with the orange wheels, the white one with the fat Harley tire or to 20" minivelo with the monster front sprocket?
LTJ.
the 20" minivelo with the monster front sprocket!! ;-)
LTJ.
Thanks jkristensen1 exactly right, they roll faster on dry pavement and grip well, they won't last as long as a bought slick but making them for free is the idea...
Plus, they look awesome!
why not buy a smoother tire?
Well if you have spare tires around you can do this instead of spending money on the new tires! Granted, they will wear out a lot quicker than if you bought new tires, but they sure do look better!
9 years ago
i like
For what it's worth, never use a grinder with one hand unlike what it says in Step 2. Install the screw-in handle on whichever side is more comfortable or practical to use, and keep one hand on the thread-in handle and the other on the main body of the grinder and switch.
