Introduction: How to Make a Homemade Pocket Knife Sharpener #2
About: Just a normal guy trying to make it in life .Good paying job but mindless sometimes .I enjoy making things in my garage to keep my mind going .. Its fun making something new but its more fun taking something…
Here is a picture of the finished sharpener ready to start sharpening small knives..
Step 1: Knife Holder Plans
Here is the illustration  plan i drew  for making the knife blade holder.
Step 2: Pocket Knive Blade Holder Fabrication
Pic#1  Shows  me milling   the 3/8 wide slots by  3/4 of a inch long.
pic #1,2,3   show the end slots  for  the 2 bearings  that  will roll on the end guide to keep the blade straight as it is rolled across the grinding wheel.
Pic#5,6,7  Show the 3 center bearing slots for the leveling of the blade holder as it passes down the  the guide.
Pic#8  Shows the clamp attached  to the holder with 3  8 x 32 x 1/2 in  screws
Step 3: Main Brackets and Supports Plan
Step 4: Main Bracket Fabrication
pic#1   Shows the (2) 1/2 inch diameter rods i drilled and tapped 1/4 x 20 x 1''  that will later be cut down to  1 1/2 inch long.
pic #2  & 3 show the drilling and cutting off of the (2)  height and support spacers
pic#4  Shows the (2) spacers installed and the support bracket welded between them.
pic #5 Shows the 14'' long  support rod for the slider bracket welded into place.
pic #6   shows the jack  support rod  for leveling the  14'' long support rod.
Step 5: Knife Slider Bracket Plan
Step 6: Slider Bracket Fabrication
Pic #1 &2  shows the milling of  all the surfaces  and the (2) slots so the bracket can slide towards the wheel for adjustments.
pic# 3 thru 7   Shows the slider bracket mounted in place ,  The adjustment bolt attached , The (2)  Spring assisted pins to hold tension on the slider bracket at all times, And the jack bolt attached and  leveled.
Step 7: Finding the Right Angle.
pic #1&2 Shows how i used a angle finder to get the  5 degrees i wanted for my pocket knife edge.
pic# 3&4  Shows the knife blade attached to the holder for both edges of the  blade to be sharpened..
Step 8: Video
hj
