Introduction: Hoop Gliders
Just like any type of flying device, the hoop glider has the four forces of flight acting upon it. Gravity (AKA: weight) is working to pull the glider down. However there is air present. Since air has mass the curved loops push against the air creating which works as lift to keep it up. The shape of the glider being thin makes it aerodynamic and reduces the amount of drag. The forward force of thrust comes from the person throwing the glider forward. The glider ends up on the ground due to the constant pull of gravity causing more and more drag on the glider, eventually bringing it down to the ground.
Key Terms
Lift – the force that directly opposes the force of gravity when discussing flying objects.
Drag – the force that tends to slow down an object moving through a fluid; also known as wind resistance, a type of friction.
Gravity – the natural force that causes an object to be pulled downwards towards an object of large mass (i.e. Earth)
Thrust – the force (or push) that accelerates an object in the opposite direction of drag.
- 2 Pieces of Paper
- Plastic or Paper Drinking Straw (if available)
- Scotch Tape
- Ruler
- Scissors
- Pencil
