Introduction: Hoppered HAMP / Semi-auto Marshmallow Shotgun
Hoppered HAMPs are manually driven, semi-automatic blasters that can be easily built with minimal tools for under $20. The power is partly a function of how hard you pull the plunger, so you can only use as much power as you need. As described here, a casual stroke will fire a 1 gram dart ~150 fps and a very hard stroke ~200 fps, but longer or shorter barrels can be used to increase or decrease the power of these sort of blasters. EYE PROTECTION IS MANDATORY FOR ALL PARTICIPANTS WHEN USING THESE TOYS!
These instructions mostly explain how to make these for special hopper-friendly nerf-like ammo that is difficult for many people to make or obtain. However they can be used to produce a semi-automatic marshmallow shotgun that uses extremely cheap and ubiquitous mini-marshmallows. There are some additional things you should know if you are going to do this.
If you're going to use these for marshmallows, there are a few differences in design and operation.
-If they get too melty they will get unremovable gook all over your barrel that will prevent it from working again.
-If they get too cold, they will be much less soft, which leads to both more target pain and fewer projectiles fed per shot.
-Stale marshmallows act like cold marshmallows. They get stale fast.
-You CAN use an easy-to-find Tee fitting instead of the wye fitting.
-Use 1/2" Thinwall pipe for the magazine. It should have an ID of nearly 3/4", but still fit in 1/2" pvc fittings.
-If you can't get 1/2" thinwall pipe, try to find something with close to 3/4" ID, and just improvise at the coupler point. Probably lots of duct tape, and you will have to reload from the cap.
-Try sch40 1/2" PVC if you feel the barrel is too tight for your marshmallows. Sch80 is usually good for most mini-marshmallows.
-If the marshmallows aren't feeding enough, you can use a follower. For example, a 4" long stick 1/2" round of nylon cannot reasonably be forced through the wye, but will push on the marshmallows in the magazine if placed on top of them. This makes reloading more of a hassle, but will usually result in more reliable and impressive blasts of marshmallows. Just make absolutely sure that the follower can't be fired.
-The amount of marshmallows fired in such a short amount of time can make cleanup taxing, depending on the environment. Ideally find a place where they can all be swept up, or a place where they don't need to be removed from.
Also, if you want a blaster that works with actual Nerf darts, there is a simpler frontloaded version of this blaster. Instructions for that are here: https://sites.google.com/site/mostlyharmlessarms/c...
Information about the ammo can be found here: https://sites.google.com/site/mostlyharmlessarms/d...
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Step 11:
Step 12:
Step 13:
Step 14:
Step 15:
Step 16:
Step 17:
Step 18:
Step 19:
Outside Contest
Summer Fun Contest
8 Comments
5 years ago
Hey Kane! Seen you before in Southwest Chicago Nerf Wars. Glad to see you have an 'Ibles account too!
Reply 5 years ago on Introduction
It's always great when cyberspace and meatspace connect. Unfortunately I'm moving out of town, and won't see you at future SCNW events. This was my first 'Ible, although I'm also on thingiverse and nerfhaven with some instructions for other blasters there that are more appropriate for their respective communities.
This is really cool, a lot cooler than the title suggests.
I would suggest changing the title to something that people who have never heard of "HAMPs" (ie most people) will still want to read it. Maybe "Pump Action Marshmallow Shotgun"?
Also, it would be nice to see the user-end view in the video - how do you load it, is there a particular grip that works well, that kind of thing.
You might be right, but as far as I can tell there's no way to change the title of an instructable once it has been created. Also, if I do figure out how to change the title, I have to keep "Hoppered HAMP" as at least part of the title, since the instructions more directly describe how to make a blaster for NIC darts, with notes on how to convert it to marshmallow use.
Just hit the Edit button and type a new one.
The URL won't change, but the visible title will (I do it quite often - look at the titles/URLs of my recent projects).
Thanks for making me take a second look. I had to edit the instructable, which doesn't by itself give me an option to change the title, but then from there edit the first step / Intro, from which I could change the title. It seems too long now, but it does mention the semi-auto marshmallow shotgun capability.
Being more descriptive, it should attract more views.
That looks really fun
