Introduction: Hot Glue Gun Waterfall!
Recently I've been wanting to make a calming aesthetic craft, and thought what better time to do it then now for the hot glue gun challenge, so I decided to go with a hot glue water fall scenery to display on my shelf!
So with that being said down below is the # easy simple steps to follow!
Hot glue gun
Pebbles
Cardboard
Hot Glue Sticks
Thin Plastic Sheet
Step 1: Layout
First,
as easy as it sounds, draw a shape on some cardboard that you would like your base layout to look like.
Step 2: Form the Pebbles
Then,
decide what pebbles you want and where to put them.
Step 3: Hot Glue Them
Then,
Simply hot glue them down, following your base layout.
Step 4: The Water
Start to fill in the gap the pebbles make with hot glue, to make it look like water.
Step 5: Stack Them
Once the base of the pebbles is filled, start stacking pebbles up on to each other, making sure to hot glue them down .
(Optional - if you want to secure your pebbles even more you can add glue tack to them)
Step 6: The Waterfall
Get a thin piece of plastic and attach it to the water and to the top of the pebble, and start to hot glue it from top to bottom, to give it that water effect.
Step 7: Paint
Once satisfied, Start to paint the hot glue, and make sure to fill all of it in.
Step 8: Cut It Out
Once it has dried, you can cut it out, and boom your finished!
