Introduction: Hot Glue Mosaic Coasters (or Tiles)
These colourful Hot Glue Mosaic Coasters are fun to make. I was looking at lego art, which made me think of iron melt beads and with the hot glue contest in the back of my mind I thought of doing this.
Instead of the cutter, jig and hole punch, you could just use a craft knife and a normal hole punch. I didn't have a hole punch of the right size, so I made one. Your punch might also get a bit gluey.
I made the cutter jig because I wanted the slices to be consistent. I made the cutter because I found it easier to cut the glue sticks with pressure from above.
7mm hot glue sticks in various colours.
Parchment paper
Clothes Iron
A surface to iron on ( used a folded tea towel to protect the surface of my kitchen counter )
Mould release ( I used Silicone spray )
Safety goggles
Dust mask
Gloves
For the mould, cutter and hole punch
3d printer
Filament ( I used PLA and it held up fine, but filament with a higher melting point, like PETG or ABS, would be better for the mould).
Tinkercad and a Tinkercad login.
Small blow torch
Calipers or Ruler
Cutter:
Craft knife with a long blade
Hole Punch:
4mm Aluminium Rivet
Dremel or drill with 2mm, 2.8mm and 3mm metal drill bits.
Sandpaper
Pliers ( I used needle nose pliers and wire cutters )
Hammer
Bench vice (or another way to clamp the rivet while drilling.)
Popsicle sticks
Step 1: 3D Printed Parts
I modeled the mould, hot glue cutter and hole punch in Tinkercad.
I've included instructions for modeling the mould in Tinkercad as I thought you might want to customise it for larger grids or thicker glue sticks. I've also included all the stl files and a link to the Tinkercad file for the mould and tools. I haven't included instructions for modeling the cutter and hole punch. They are both made up of simple boxes and cilinders in Tinkercad. I'm happy to answer any questions regarding the 3D modeling or anything else.
hot glue coaster mould and tools
Step 2: Making the Coaster Mould
Open Tinkercad and log in. Start a new project.
1: Create the grid
In The shapes panel search for "grid".
Select a shape called "grid of square columns" and enter the setting as follows:
Columns: 10
Rows: 10
Size 7.5 ( The diameter of a glue stick + 0.5mm tolerance. )
Gap: 0.4 ( I wanted the blocks seperated by a very thin line and this is the width of my printing nozzle.)
Height: 3 ( This will be the thickness of the coaster. )
The finished grid should measure 78.6mm x 78.6mm. This will be the size of the coaster.
From the basic shapes menu add box and scale it to 78.6mm x 78.6mm x 2mm.
Click on align and align it to the top of the grid.
2: To make the rounded corners
From the basic shapes menu add a box, make it a hole and set the radius to 1.
Scale the box to 78.6mm (width )x 78.6mm (length) x 20mm (height).
Add another box and scale it to 80mm (width )x 80mm (length) x 10mm (height).
Select both boxes and click on "align". Center the boxes and then group them.
Make this new object a hole.
Centre align this object and the grid and group them.
3: Complete the mould
Add a box and scale it to 83mm x 83mm x 4mm (height).
Align this box and the grid with the rounded corners from the previous step, so that they are centred on the x and y axis.
Align the grid to the top of the new box.
Make the grid a hole.
Group the grid and the box
Select the new object. Click on export and select stl.
I printed the coaster mould in PLA with a layer hight of 0.28 and 25% infill.
Step 3: The Blade Grip and Cutting Guide
Download and print the blade grip and cutting guide stl files. I printed them in PLA with a 0.28mm layer height and 25% infill.
Break a section of three blades off a long craft knife blade. I put the blade in a craft knife and used pliers to break it off.
Insert the section of three blades in the blade grip. If it's a bit loose, either heat the blade with a blow torch before you press it in or add a bit of hot glue to the blade before you press it in. If the fit is too tight, heating the blade will help too.
Place a glue stick in the cutting guide.
Place the blade in the blade slot of the cutting guide and press down.
Step 4: Making the Hole Punch
Download and print the hole punch housing and hole punch guide stl files.
Start by separating the inside and the outside of the rivet. I did this by holding onto the each part with a pair of pliers and pulling them apart a bit to start. Then I held the tube in the needlenose pliers and hit the sharp end of the peg with the hammer. Keep the peg for later.
A drill press would be handy for the next step, but I don't have one.
Put the rivet tube in a vice with the narrow, sharp end facing up.
I put it between popsicle sticks to protect the vice. The metal gets quite hot and I damaged the rubber on my vice a bit on my first try.
Using a 2mm drill bit, carefully and slowly drill about 5mm into the rivet to make the opening larger. Try not to go deeper, as the metal becomes too thin and soft. Do the same with the 2.8mm drill bit and then with the 3mm drill bit, to gradually increase the opening to 3mm. Gradually increasing the side of the drill bit resulted in the neatest cutting edge.
Clean up the edge with sandpaper if it's necessary.
Insert the rivet tube into the hole punch housing.
Heat the tip with the blow torch and put the punch housing in the punch guide, so that the rivet tube goes through the hole in the bottom of the guide.
The heating of the rivet helps secure the rivet in the punch housing and melts the plastic of the punch guide, in case the hole is slightly too small for the rivet.
put the rivet peg through the hole to help align the rivet tube, punch housing and punch guide and let it cool.
Step 5: Planning Your Designs
I made three coasters. I planned the first one in Adobe Illustrator using coloured circles.
For the second one I just built it directly in the mould.
Because I made the third one out of leftover disks from the first two, I printed out a template of the grid (made in illustrator) and planned it on paper with the leftover disks before I transferred them to the mould.
You could also just draw your designs on paper with markers or coloured pencils.
Keep in mid that the final coaster will be a mirror image of the design you see in the mould. If the robot's looking to the right when you're placing the disks in the mould, it'll be looking to the left on the final coaster. Especially keep this in mind if you're planning to use text as part of your design.
I've included a pdf of the printable grid.
Step 6: Cutting Hot Glue Disks
Using the cutter and cutting jig or a craft knife and ruler, cut up some glue sticks.
If you planned your designs, count how many disks you need of each colour. If not, just cut disks of the colours you like. You'll need 100 glue stick disks per coaster.
Step 7: Punching Holes and Dots
Put one of the hot glue disks in the hole punch guide.
Put the punch in the guide and press down. Depending on how hard your glue sticks are, this might take a bit of force. For some of the disks I used a hammer to hit the top or bottom of the punch to get the last bit through.
Use the rod you removed from the rivet to remove the hot glue dot from the punch.
Remove the punch from the guide and remove the leftover hot glue disk from around the punch.
You now have a disk with a hole and a dot. Combine dots and disks of different colours by pressing a dot into a holed disk of another colour.
Step 8: Assembling the Dots in the Mould
Spray the mould with mould release. I used silicone spray and while I didn't try anything else, I think cooking spray might work too.
Arrange the hot glue disks in the mould. The side facing down is the side you'll see in the end, while the top will be melted. If a disk is a bit rough on the one side, face the better side down.
Step 9: Melting the Glue
Do this in a well ventilated area.
Protect your work surface from the iron. I worked on a folded tea towel.
Place the mould with the hot glue design on some parchment paper ( to protect the surface from glue).
Place two more sheets of parchment over the design. The first one will stick to the hot glue while it's melted. The second one will move with the iron and help it to move over the mould smoothly. It also adds another layer of glue protection for the iron.
Test the heat of your iron with a couple of pieces of hot glue between parchment. You want the coolest setting that will melt the hot glue. The plastic mould will hold up better if the iron is cooler.
My iron was set to the Nylon setting and the PLA mould held up fine.
Place the hot iron on the parchment and slowly move it around, checking every few seconds to see if the glue as melted. Just lift off the second layer of parchment to check the glue. If it's sticking to the parchment everywhere and the top looks smooth, you're done ironing. Leave it to cool. It shouldn't take very long to cool.
Step 10: Removing the Coaster From the Mould
When the coaster and mould has cooled, peel off the parchment.
If the hot glue stuck to the outside edge of the mould, with the blade or a craft knife, carefully cut around the inside edge of the mould to release the coaster.
Use the same blade to lift a corner and then use your fingers to lift the coaster. Work carefully and from the outside inwards.
Wipe off any mould release with paper towels.
Trim the edges with a pair of scissors.
That's it! Enjoy your coasters and remember to switch off the iron when you're done.
Second Prize in the
Hot Glue Speed Challenge
10 Comments
12 days ago
Hi Did you test a hot cup of tea or coffee on these coasters?? They are well done but I would think the glue will melt with heat from another source.
Reply 9 days ago
Hi. Thanks for your comment. I was worried that it would melt, but I've been using it with cups of coffee and it seems okay. I just double checked by pouring freshly boiled water into a warmed glass cup on the coaster and checking it every minute or so. It doesn't seem to have affected the coaster at all.
Different hot glues melt at different temperatures, so that might be something to keep in mind. Testing the hot glue with a hot cup or glass before using it for coasters would be a good idea :)
10 days ago
Cool! reminds me of perler beads
Question 11 days ago on Step 1
Please can you explain the diferece between your hot glue idea and "iron on beads"
12 days ago
This is so darn clever! I love the use of 3D printing to enable other non-3D printing creations. I'm definitelly gonna give this a try, but more importantly, this is great inspiration for other ways 3D printing can create jigs for other art ideas! Thanks for sharing!
14 days ago
This is awesome!! Never thought of using hot glue to make Legos, super cool!!
17 days ago
I love this idea! Very clever and creative use for glue sticks! : )
Reply 16 days ago
Thank you :)
17 days ago
This is a really neat idea and the results are fantastic!
Reply 16 days ago
Thank you :)
