Introduction: House in a Bottle V2
Hi All,
Last year I made my first, "House in a bottle", That was the first time I built a house inside a glass bottle. It was more like proof of concept.
This is my version 2, where I have added few finner details
- Mud on the floor
- Grass
- Moss/creeper on House
- Doors and Windows
- Chimney
- Tree
And simplify the build without the use of any special tool
Step 1: What Do We Need?
- Glass bottle: I used Old monk
- 10mm Wooden sticks
- wodden Coffee stirrer sticks
- Green crepe paper
- Long Skewer
- Toothpicks
- Wooden Match sticks
- CocoPeat
- Hex saw
- Acrylic paints
- PVA glue or fevicol
- Dremel
- Clear Resin
- Old Hanger
- paper tape or masking tape
Step 2: Prepare: Bottle
- Wash the bottle with soap
- Remove all labels, to remove glue stains use hand sanitizer liquid
- Let the bottle dry and there should not be any watermarks when done
- I used clear epoxy resin to flatten the base
Step 3: Build: House
- To build the house, I have used 10mm wooden sticks
- Each piece of the wall is cut at 45 degrees at a length of 45mm
- We need 12 pieces for the wall
- For the roof support, we need 2 x 45mm pieces and 2 x 25mm
- Stack the pieces together to make the house
- Since these are cut by hand, there may be gaps
- Adjust the pieces to reduce gaps as much as possible
- Label each wall from inside and then drill a hole through all of them
- The hole should be able to keep all the pieces aligned as shown
- I used a toothpick
- The chimney was a leftover piece with 45 degrees cut on one side ( 15mm length )
Step 4: Build:Roof
- The roof is made using coffee stir
- Cut 12 to 14 pieces to a length of 55mm
- Stick them using a paper/masking tape
- Place on the house and adjust the length, if needed
Step 5: House Detailing
- Paint the house with a brown acrylic
- Dry brush dark and light green on them
- Using match sticks make two windows and a door
- Paint them dark brown as shown
Step 6: Assembly: House
- Draw a square of 45mm on paper and place it below the bottle
- Drop-in some fevicol or PVA glue, and spread it using a skewer
- Drop the first piece on the sides away from the glue
- And using skewer adjust it position to align with the square drawn on the paper
- One by one place the 3 pieces and adjust their positions to make a perfect square
- After each layer, let the glue dry for 1 hr, before continuing
- Don't start with the roof, let this dry for a day
Step 7: Assembly: Mud and Roof
- Before we start with the roof, we need to add some details
- Pour a mixture of glue and water(2:1) outside the house, (not too much)
- Sprinkle some cocopeat and let it dry for 1 hr
- Now sprinkle some green colored cocopeat
- Stick a thin thread on the roof, using tape
- Use the thread, to adjust the position on the roof, and glue it on the house as shown
- Leave it to dry and then gently pull out the thread
Tip:
- Use a tea or coffee filter to separate the bigger chunks on the cocopeat. We need the fine cocopeat to simulate the mud, grass, and creeper
- Using thin thread
Step 8: Build: Tree
- Cut a long strip of crepe paper (80mm width)
- Cut them into thin strips as shown
- Place these on a thin metal wire and twist the wire as much as possible
- Using a scissor, shape the tree
- Add a base using a small button
Step 9: Assembly: Tree
- Apply glue on the base where you want to place the tree
- Gentling push the tree as shown
- And place it in position and let the glue dry
Step 10: Finishing
- Let the bottle dry for a week
- Stick tissue paper on a piece of a hardwire and clean the bottle from inside
- You may have to damn the tissue paper to remove glue etc
- let the bottle dry in shade, not in the sun
- Close the cap, optionally add some fairy lights
- We are done. place it on a shelf and adore it
I hope someone follows these steps and makes one
Please share your comments and suggestions
