Introduction: HoverCraft Fablab61
This HoverCraft was made by Rostov Summer's School's team special for Fablab :) Our masterpiece was our first experience in this sphere. Create & enjoy!
Step 1: Foundation
Take foam =20mm. Cut a foundation from foam 200mm x 300mm. Cut the circle from foam d=140mm & stick to the foundation.
Step 2: Skirt
Cut a skirt l=1m, w=40mm. Stick this skirt to the foundation.
Step 3: First Propeller
Take first three-bladed propeller d=130mm. Fix it into a circle.
Step 4: Back Protector
Use this plan and cut a back protector from foam for your second propeller. Stick to your foundation
Step 5: Second Propeller
Take these plans and cut it (use plywood). Collect it. Then Fix second propeller to the construction
Step 6: Radio Receiving Equipment
Check yourself. You need:
1) Arduino Pro Mini (on ATmega168, 5V, 16M) - 2 pcs
2) Wire-modules XY-MK-5V & XY-FST (FS1000a)
3) Joystick module Keyes_SJoy.
Connect the modules (use scheme for this step, look at the files :) )
Fill sketches for arduinos in any convenient way.
Step 7: Motor
Check what you have:
- Motor MT 1806 (x2)
- Regulator DUALSKY XC 1210 BA (x2)
- Battery (LiPol 11V 1Ah)
- Servo SG 900
The motor connect to the regulator. The regulator connect to the battery and the radio receiving equipment.
Step 8: Final
Connect your foundation with motor & radio receiving equipment. Check this out!
If you want you may create your own special design & logo for HoverCraft :)
