Introduction: Hoverboard Car
This project was just something I made because I was bored. I based it off of one similar project my friend made.
Step 1: What You Will Need
You will need these things:
Hoverboard (Smart balance scooter)
Two Razor scooters
Two pieces of wood with the dimensions of 1x5 1/2x17 5/8
One five gallon bucket
About 15 2in long screws
One pieces of 1/2 in PVC pipe
Step 2: The Frame
For this step you will need both of the scooters, both pieces of wood and 8 of your screws. First take the two scooters and screw on both boards one on the front and one on the back. Then take off the handle bars on both scooters. Move on to the next step.
Step 3: The Hitch
For this step you will need your PVC pipe and some more screws. When I built this I used a piece of scrap wood but it broke in half so I replaced it with 1/2 in PVC. Take your PVC and line it up in the middle of the platform and screw it in with about 3 or so screws. Then drill a hole that can fit your bungee cord hooks. Drill he hole all the way through the pipe and move the drill bit around to enlarge the hole.
Step 4: The Seat
For this step you will need the five gallon bucket and four screws. Line the bucket up in the middle of the platform then screw the four screws in a square around the bucket on the lip. Set a cushion on top and you are almost done.
Step 5: Attaching the Hoverboard
You will need your bungee cord for this step. Attach one hook from the bungee to the pipe then wrap it around and hook the other end in the hole. You are finished.
