Introduction: Update Facebook Username for 2017
Well, here's one of the simplest methods to change that Facebook Username you're no longer comfortable with
You won't be able to input a new username, however if your current username is one that you aren't ok with and you would prefer the default then this will certainly help you.
Step 1: Copy Your Current Username
Log in to your Facebook account
Go to settings and select username
Step 2: Create a Facebook Page
If you don't already have one that you can use, you are going to have to create a new page.
This does not need to be anything specific.
Step 3: Proceed With the Steps
Add the information required for the page to be created and skip through any unnecessary steps.
You will delete this page after when you're through changing your profile username.
Step 4: Invite Friends
Invite at least 25 persons to like your new page.
Step 5: Change Your Page's Web Address
At this point it's best to have two browser tabs open - one with your Facebook Profile, the other with your Facebook Page
- Go to settings on our Profile and select username
- Copy the section of the URL that follows "facebook.com/"
- Now go to your new Page, click on "about" and look for "Facebook Web Address"
- Click "Edit" then click "Change Web Address"
Step 6: Transfer Profile URL
Almost there.
- Replace the section of the URL that follows "facebook.com/" with what you copied
- Check availability, Proceed with Transfer
After this you will realize that silly username you may have chosen some years ago for your profile that you thought was cool but now regretting, has been transferred to the new page you created.
Your Facebook profile will now have a default username/url.
Step 7: Finally....
After all the steps are followed and you're at this point, you may delete that temp page you create.
You will find the step by step process in the video below:
