Introduction: How I Costum My Glasses by Adding a LED
In this Instructable I will show you how I add a LED lamp to my glasses.
Step 1: Materiels
1- Super glue.
2- Hotglue.
3- Lighter with a built in LED lamp.
4- Hacksaw or this costum saw/knife cutter I made (instructable for the project from here).
Step 2: Opening the Lighter
1- I Took apart the lighter.
2- I took the plastic piece where the LED lamp was inserted and I cut it in half using the sawblad.
3- I sand the plastic piece with a fill then sandpaper.
Step 3:
1- I measured the bottom of the plastic piece.
2- I cut off a piece of plastic from CD case.
3- I put super glue in the bottom of the red piece
4- I glued the plastic piece from the CD case in place
Step 4:
1- I took the front plastic piece that hold the LED lamp and cut it in half.
2- I put the LED in place to make sure everything works fine.
3- After I removed the LED lamp I paint the pieces with black matt sparycan.
Step 5:
1- I put LED lamp in the case, I put some super glue, then I glued the front piece in place.
2- I put hot glue in the Bottom of the piece.
3- I glued the LED case in the side of my glasses.
I hope you liked this Instructable, thank you.
