Introduction: How Install LED Strips Under Kitchen Cabinet
LED kitchen lighting is usually frustrating, generating it challenging to determine whether or not your chicken breast is cooked via or see how much seasoning you place on a dish, amongst other concerns. An easy option to this dilemma is to install LED strip lights within the kitchen. These easy however bright strips are usually installed or removed speedily without having damaging your cabinets. They can present the light you will need with no expense of replacing or installing new overhead lighting.
Step 1:
Figure out exactly where you would like to set up the 5050 LED strip lights. Most frequently, these strips are best suited for under-counter lighting. However, you may also install them on the sides of the cabinets to illuminate a gap involving the units. By way of example, in case your kitchen sink features a cabinet on both sides, you are able to install LED strip lights on the sides of these cabinets to provide additional lighting in this location.
Step 2:
Step 3:
Step 4:
Step 5:
Draw a straight line with a ruler and pencil exactly where you want to install the LED strip lights. This acts as a guide for installing the clips.
also you can consider use the GX53 LED kitchen under cabinet lighting lamps in your kitchen,perfect design,patent aluminium shell,best choice for your kitchen.
