Introduction: How Make an Automatic Sugarcane Farm in Minecraft.
Today I am going to show you an instructable on how to make an automatic sugarcane farm
To make a single box you will need:-
- 1 Sand
- 3 Redstone dust
- 2 Hoppers
- 1 Chest
- 9 Building blocks
- 1 Sugarcane
- 1 Bucket of water
- 22 Glass Blocks
- 1 Piston
- 1 Observer
These all are approximate values( some resources may be left out and some extra may be needed )
Step 1: Base
First using your building blocks, create a base like this
Step 2: Function
At one side, place a building block and place a piston above it facing inwards and also place an observer above the piston facing in wards, this is going to be your circuit system. Now in the two block hole, place a sand towards the circuit and water away from it.
Step 3: Collection
Place a hopper below the water facing downwards. Now, place another hopper below the hopper facing front. Now place a chest in which the second hopper should be connected.
Step 4: Redstone and Sugarcane
Now using the building blocks, build a structure in which the blocks are behind the piston 2 block below, behind the piston and 2 blocks behind the building block which is below the piston. And now place the redstone dust on the three building blocks. This will complete your full circuit system. Now place the sugar cane on the sand( and by the way, you can use dirt there instead of sand ).
Step 5: Caging
Now cover your box properly with glass and do not disturb any of the circuit system. (No need to cover the circuit)
Step 6: Check
I have done AFK for approximate 10 to 15 min. You will get over a stack of sugarcane.
Note:- Sorry for the darkness, I was very busy while I was doing it, so could not notice, it was night time.
