Introduction: How to Boot Raspberry Pi With NOOBS
Step 1: What You Will Need
Required materials:
•Raspberry Pi (of course)
•Sd card [8Gb SDHC "class 4" Recommended]
•HDMI Cable or Video and sound out cables
•Monitor Or TV that corresponds with your output type
•USB Keyboard
•Mini USB cable (or like phone charger)
•wall to USB adapter [NOTE: in between 4.5 and 5 Volts. If larger could DAMAGE your Pi. If lower wouldn't boot]
Recommend Materials:
•Ethernet or WiFi dongle
•USB Mouse
•Powered USB hub (if you plan on adding more USB devices than you have room for or if they draw too much power)
Step 2: Preparing Your Sd Card
The most important part of the Pi is the Operating System. The second is how much storage you have. To get the most out of your Pi you must format the Sd card. Use the following link, https://www.sdcard.org/downloads/formatter_4/ ,and download the Sd Association Sd formatter for your system. Run the tool and make sure to pick the correct drive. After you have to install the operating system(zip file) . Go to the Pi Foundations downloads page using the following link, https://www.raspberrypi.org/downloads/. In this tutorial we will be using NOOBS offline and network install. Basically, in this version of NOOBS it comes with the operating systems pre installed, so an Internet connection isn't required. If you would like to use NOOBS lite you can. Keep in mind that you will need an internet connection. The offline OS is a full operating system, so keep in mind it takes anywhere from 25 to 30 minutes to download. (Depending on your internet connection) after the NOOBS .Zip file downloads, you have to extract it. Extract it using a pre installed tool. Alternatively you can use 7zip or a like program. After the files extract you have to copy or move the recently extracted folder, onto the Sd card. Now extract the Sd card and gaze at all your hard work. But it's not over yet
Step 3: Putting Everything Together
Step 4: Setting Up the Os and Configure the Pi
Step 5: Booting Into the Graphical Interface
" raspberry Pi login:" the default user is Pi. Type it and hit enter. The default password is raspberry. Keep in mind that when you type it you won't see any asterisks or characters. It is just a security feature of Linux. After you enter your password you will see " pi@raspberrypi:~$ " to boot into the graphical interface type "startx"
Step 6: Final Regards
•Robots
•quadcopters/drones
•personal server
•personal playback device
•retro gaming cabinet/ machine
Note that some projects may need a certain operating systems and different versions of Pi to run. The newest models have twice the ram and half the loading speeds
