How to Build a Computer
Intro: How to Build a Computer
Computers are less complicated than they seem. when your building your computer make sure you buy your motherboard first because all the other pieces you buy need to be compatible with your motherboard or the computer wont work properly.
Another precaution to take is static, static will damage your computer components an anti static bracelet will ground you to your computer so the static is dis charged and it won't harm your pieces.
STEP 1: What You Need
- Motherboard
- RAM( Random Access Memory)
- CPU(Central Processing Unit) With heat sync fan
- Hard Drive and/or Solid state drive with brackets
- Power supply
- A Casing you can buy one or you can use an old one from an old computer
- sata cables( if the don't come wit the hard drives)
- video card if it isnt built into the mother board
- software
- A Wire-less nic
- Power supply
- software
- A Wire-less nic
STEP 2: The Mother Board
the mother board is the most important part of the computer
it is the housing of the CPU and controls all the input and out put
STEP 3: RAM
RAM stands for random access memory
RAM is very important RAM is the simple memory of your computer
most web browser use Ram to hold the history, Ram doesn't hold documents it just holds the simple things your computer needs
STEP 4: CPU
this is the brains of the computer it is also the most expensive piece of the computer unless you buy an expensive video card
CPU's often come with heat sync fans so it doesn't over heat and blow
STEP 5: Hard Drive
The hard drive is the piece in the computer that stores your documents, pictures, ect.
If you want you can also buy a solid state drive to go with your hard drive
If you choose to buy a solid state drive to go with your hard drive your computer will boot up much faster and load files, pictures, and documents much faster.
I would NOT recommend just buying the solid state drive because it cant store as much information as a normal hard drive can
STEP 6: Power Supply
The power supply is pretty straight forwards
it evenly distributes power where it needs to be in the computer
STEP 7: The Casing
The casing is the housing of all the components
Cases can range from $30-$200
STEP 8: Video Card
The video card is some times refereed to as a graphics card
if you think you will be playing allot of games on your computer you will want to buy a good video card
we didn't buy a video card because it was built into the mother board
STEP 9: Software
You can buy software of you can use Linux if you think you want to customize the way your computer runs
STEP 10: Wire-less Nic
nic stands for Network Interface Controller
this is the piece that will allow you to use wifi
STEP 11: Assembly
Before you assemble Make sure that all you components are compatible with the mother board
because if they aren't pieces can be damaged
Also make sure that you have your anti static wrist band on and it's clipped to the casing.
STEP 12: Step 1
Install Your power supply
your power supply should come with screws to mount to your case
STEP 13: Step 2
Putting in the CPU
putting in the CPU is a delicate process you need to be careful when putting it in because you don't want to bend any of the pins the CPU sits on
There should be a little lever that you pull over and up to open the socket for the CPU make sure to take the plastic covering off before putting in the CPU
STEP 14: Step 3
Mounting the optical drive
you will need to punch out one of the slots in the front of the case then insert the optical drive and there should be a lever or button to lock it in place
STEP 15: Step 4
Mounting the mother board
the bottom of the casing should have holes and the casing should have come with hex screws to screw into the bottom of the casing
then you put the mother board on top of the hex screws then the casing should have come with other screws that screw into the top of the hex screws to secure the mother board
After you mount the mother board you will need to put the heat sync fan on top of your CPU and just click it into place
STEP 16: Step 5
Putting in the RAM
When you take the RAM out of the box DO NOT touch the gold part of stick
you will need to apply a good amount of force till you hear a click then you know its in
STEP 17: Step 6
Inserting the hard and soft drives there are slots that they slide into but the soft state drive will need to have brackets for it to fit right
STEP 18: Step 7
now you will need to insert the wire-less Nic card
this is the same prosess as the RAM
STEP 19: Step 9
Connecting the wires
you will need to look at all the manuals to see where all the cables need to attach because all computers are different.
STEP 20: Step 10
Once you have all the wires connected you will need to plug it in and boot it up
once you have it booted up you will need to set the bios
the bios are the setting of the input and out put and it is very straight forward
STEP 21: Step 10
After setting the bios you will need to put the software in and install it
witch is also very straight forward
STEP 22: Finished
My dad and i built this computer for just under $600 so it was very cheap and fun to build
it also only took us 3-4 hours to do it
So this is a fun little weekend project that I hope you enjoy
If you liked this project follow me and check out some of my other projects. Thanks.
4 Comments
cjs1298 10 years ago
pfred2 11 years ago
By the way I have that exact same power supply in this PC and inside of 6 months the fan started making terrible noises on me, so I had to pull the PSU all apart, take the fan out of it, and lubricate it. Yeah, when I bought it I thought Antec stuff was pretty good too. Turns out the fan they put into the value PSU is a pretty lousy one though. This is the one I found inside of mine:
http://www.jab-tech.com/YATE-LOON-120mm-Case-Fan-D12SH-12-High-Speed-pr-3771.html
Some chainsaw bar lube and mine has been running fine now though. Either that or it completely seized up. At least it doesn't make noise anymore.
thegeeke 11 years ago
Technically you are correct that it is not grounded unless it is plugged in, but the case of the computer is metal... it can help absorb ESD. Think about when you touch something metal (not grounded) when you have static built up... what happens? You get shocked. Why? Because you had a ESD into the metal. The ground strap just makes sure that you are always touching metal and it is transferred into the metal. Is it truly grounded? No... but it helps. (Again, this is why I use self contained straps)
nlaspelotas 11 years ago
