Introduction: How to Charge Your Ipod, Camera, Cellphone or Handheld Game Console on the Go
length=5.6cm height=3.1cm
width=8.2cm
output=5vdc 1A
battery life=over 3 hours
Step 1: Gather Materials
1-battery connector
1-switch
1-100uf capacitor
1-5v voltage regulator
1-rectifying Diode
1-220uf capacitor
1-150ohm resistor
1-led
1-330ohm resistor
1-10kohm resistor
1-female usb port
1-pcb board
1-9v battery
1-project box
Tools
soldering iron
solder
philip screw driver
drill
16/64" drill bit
handsaw
hot glue gun
knife
vice
dremel
Step 2: Solder the Components on the Printed Circuit Board
BT1=battery connector
K1.1=switch
C1=100uf capacitor
U1=5v voltage regulator
D2= rectifying Diode
C2=220uf capacitor
R1=150ohm resistor
D1=led
R2=330ohm resistor
R3=10kohm resistor
Female usb port
Step 3: Cut the Printed Circuit Board
To cut the pcb you must clamp the pcb in the vice with the top of the vice in line with the spot where you want to cut the pcb. Then run the knife along the top of the vice 20 times with pressure on the pcb. Flip the board over and do the same with the other side. Next squeeze the sides of the board. Then bend the board and it should just snap off cleanly if you ran the knife along the top of the vice the right number of times.
Step 4: Modify the Case
Step 5: Put Everything in the Case
Screw the pcb to the case or glue it. Next hot glue the led in the hole you made earlier. Then hot glue the usb plug in the slot. Now put the Battery in the case it should fit tightly.
Step 6: Put the Top on and Try It Out
Now screw the lid on. Then try it out by plugging something in the usb slot and turning your Portable USB Power Supply on.
