Introduction: How to Create a Sexy Cat-Eye Look
In this fast-paced, capitalist world, where every commercial and magazine is telling you to "Do this" and "Stop that", "Buy this" and "Shed those extra pounds". There's always constant pressure to be some insane standard of "beautiful".
A first impression is extremely important in many facets of life. So here's my instructable on one of the first steps you can do to put your best face forward!
I know you are all beautiful without make up, but I'm hoping these techniques will help enhance your already gorgeous eyes!
Step 1: Step 1: Mascara
Coat the upper and lower lashes with a coat of mascara. I suggest doing the top one first.
Place the wand at the base of the upper lashes, sweep up while wiggling the wand from side to side.
Now, looking down slightly, coat the other side of your lashes, now you have mascara covering the entire lash.
Finish the upper lashes by placing the wand at the base of the lashes and sweeping upward from root to tip.
On the bottom lashes , use the tip of your wand (make sure there's no 'goop' on the end) and bush it from left to right, giving them a light coating. Make sure to separate any clumped lashes!
Repeat on the other eye.
Step 2: Step 2: Eyeliner
Using a well-sharpened eyeliner pencil, draw a thin line as close to the lash line as possible.
Make sure you start your line a quarter of the way out from the inner corner of your eye. If you start from the very inner corner, it will close your eyes up and make them look smaller. We don't want that, do we now!
When you're nearing the outer corner of the eye, you may thicken the line slightly.
At the very outer corner, wing the line outwards, following the shape of the lashes.
Step 3: Step 3: Base Shadow
The next step is to take a nude shimmery peach or beige and apply it to the entire lid (the shade on the left).
Using your finger or an eye shadow brush, apply this neutral colour starting at the top to the eyeliner all the way to the eyebrow.
Make sure it covers the whole area above the eye, from the inner corner to the outer corner, to about where you winged eyeliner ends.
Step 4: Step 4: Contouring Shadow
Next, use a darker complementary shade in the crease (the shade on the right). Usually, two colours will come together, making this even easier!
Load an eye shadow brush with the darker colour, making sure to tap off the excess, and dab it into the outer area of the crease. Extend the colour about halfway across the eye. Again, applying it to the entire crease will close in the eye, making it look smaller.
On the outer edge, extend the shade slightly up and out, following the line of the eyeliner, this is what really gives the "cat eye" look!
Step 5: Step 5: Brighten
The final step is very simple.
All you do is dab your pinkie or ring finger in some white eye shadow, and dab it in the inner corners of the eye.
This will instantly brighten your eyes, and make them look farther apart and more open! You'll look just like Kate Moss!
Step 6: You're Done!
Now if you follow these few simple steps, you'll soon be as beautiful as everyone thinks you should be!
