Introduction: How to Create an Adobe Flash Web Site
Spice up your online presence by creating your own Flash site. Here's how.
You Will Need:
* A computer with internet access
- Adobe Flash CS4
Step 1: Step 1: Create New Flash Document
In the Adobe Flash program, select Flash File (Actionscript 3.0) from the Create New menu. Switch the workspace layout by clicking on the dropdown menu in the upper left of the top menu bar, and selecting Designer. You can adjust the size and color of the document by adjusting the settings in the Properties panel.
Step 2: Step 2: Create New Layers
Divide your Flash document into four layers: Actions, Background, Menu, and Pages. To do this, go to the Flash timeline, and click three times on the New Layer icon so you have four layers total. Rename each one by double-clicking on the name, or holding the mouse down on a Mac.
Step 3: Step 3: Adding a Background
To add a background image, select the Background layer from the timeline. Then, go to File, Import, and Import to Stage, and select the image you want to use. You can change the size of the background in the Properties panel once the image is imported.
TIP:
To prevent accidental changes, lock a layer by clicking on the second dot directly to the right of the layer name. The dot should change to a padlock icon.
TIP:
Step 4: Step 4: Create the Navigational Menu
Select the Menu layer from the timeline. From the top menu, select Windows, Components. In the window that appears, double-click the Button component under the User Interface section, which adds a button to the document. Position the button where you want the menu to be. Repeat this process to add as many menu buttons as you need.
Step 5: Step 5: Enhancing the Buttons
Select the first menu button you added. In Properties, change the instance name to button1. Change the name displayed on the button by selecting Windows, Component Inspector from the top menu. In the resulting window, change the label value. Continue this process for the remaining buttons.
TIP:
Make sure the instance name is a relevant label with no spaces, capital letters, or special characters.
TIP:
Step 6: Step 6: Add a Title
To add a title to your web site, select the text tool from the Tools panel. In Properties, change text attributes, like the number of lines, font, color, and size. Then, click on your document to add text.
Step 7: Step 7: Create the Content Container
Create pages to add content to your site. Select the Pages layer from the timeline, and then click on the rectangle tool in the Tools panel. Adjust color and transparency from the Color panel. Then, draw a rectangle on the document to match the size you want your content to be.
Step 8: Step 8: Hold Shift
Add pages in the Pages layer. Hold down the Shift key, and select the Background layer. This will select every layer except for Actions.
Step 9: Step 9: Copy and Paste to Add Pages
Right-click (or command-click for Mac) the first frame of the Pages layer and select Copy Frames. Right-click the second frame in the Pages layer, and select Paste Frames. This is where the second page will be. Continue this process for as many pages as you need.
Step 10: Step 10: Adding Content
Add content. Select the first frame of the Pages layer. In Properties, change the label name to page1. Then, use the text tool from the tools panel to create the text for the first page. When you are satisfied, go back to the Pages layer, select the second frame, and repeat the process. Continue until you have content for each page.
Step 11: Step 11: Create the Actionscript
Select the first frame of the Actions layer and hit F9. In the Actions window, type a stop script to stop the pages from cycling. Hit Enter to go to the next line, and create a function for each button that tells it which page frame to jump to. Hit Enter and write a script that attaches the functions to their corresponding buttons, using the button instance name.
TIP:
To preview the document in action, go to Control > Test Movie from the top menu.
TIP:
Step 12: Step 12: Publish and Upload
Publish the web site by going to File, Publish Settings. Check both the SWF and HTML boxes. Rename both files, and select a location to save it to. Then click publish, and upload all of the published files to your web server. To access the Flash page, just navigate to the HTML file on your web server. Youre done!
