Introduction: How to Crochet a Hat!
Need an idea for a Holiday Gift? How about one for yourself -- in EVERY Color! How to Crochet a Hat!
Check out the Threadbanger Episode here! or down below:
Step 1: Materials
Materials:
10.5 Crochet Needle
Yarn
10.5 Crochet Needle
Yarn
Step 2: Step 1
1. Begin with a slip stitch and 8 chain stitches.
Step 3: Step 2
2. Connect the two ends by putting your needle through the first stitch and do 2 single crochet stitch in each stitch so you end up with 16 stitches around the outer ring.
Step 4: Step 3
3. For the second row:
1st stitch: do 1 single crochet stitch,
2nd stitch: do 1 single crochet stitch,
3rd stitch: do 1 single crochet stitch,
4th stitch: do 2 single crochet stitches,
do this repetition until you reach the beginning of the row marked by the tail.
Step 5: Step 4
4. The third row is a single crochet stitch all the way around.
Step 6: Step 5
5. The 4th row is 2 single crochet stitches in each stitch all the way around. Try to keep your hat flat, you don't want it to roll quite yet.
Step 7: Step 6 - 15
6. The next row is:
4th stitch: do 1 single crochet stitch,
5th stitch: do 2 single crochet stitches,
7. When you reach the beginning again, its a single crochet stitch all the way around.
8. The next set is:
5th stitch: do 1 single crochet stitch,
6th stitch: do 2 single crochet stitches,
8. Once again, when you reach the beginning again, its a single crochet stitch all the way around.
9. The next set is:
6th stitch: do 1 single crochet stitch,
7th stitch: do 2 single crochet stitches,
10. Instead of doing a row of single crochet all the way around, do the counting rows again only modify stitch 8:
7th stitch: do 1 single crochet stitch,
8th stitch: do 2 single crochet stitches,
11. Counting row again, but modify the 9th stitch:
8th stitch: do 1 single crochet stitch,
9th stitch: do 2 single crochet stitches,
12. This row, the same counting technique but modify to do 2 single crochet in stitch 10.
13. Modify the same counting row to do the 2 single crochet in stitch 11.
14. Again for stitch 12.
15. Against for stitch 13.
8. The next set is:
9. The next set is:
Step 8: ** Note **
If you run out of yarn, simply tie the end of the used yarn to the end of the new yarn
Step 9: Step 16, 17 & 18
16. Single crochet in everything stitch around and around and around until you've reached your desired depth. You will start to notice the hat curl, this is expected.
17. Once you've reached your desired depth, you need to close up the rim. We're back to counting:
SKIP 4th stitch,
18. For the final row, repeat the counting in step 17 but skip 2 stitches. Pull the loop out really big, snip the end and tie a knot and you are DONE!
SKIP 4th stitch,
