Introduction: How to Grow Food Off the Ground in Pipes, (especially Hanging Plants)
Hi here is my instructable on how to grow vegetables off the ground to avoid pests , decrease water use, organically fertilise and save you bending over to pick up the vegetables so no more back pain. Also a very good idea when you can grow off the ground where there is snow because your veg can be covered with a gloche or glass jar and the rising heat from the ground will keep it warm
Step 1: Find or Buy a Pipe
So go out and get a pipe about 10cm-15cm wide and cut to desired height taking into consideration about 30cm off the bottom that will be buried
Step 2: Dig a Hole
So make a whole a put in the pipe about 30 cm deep and cover with soil
Step 3: Step on It
Dance around the pipe to make the foundation strong
Step 4: Fiill It With Compost Material
Go and get your juciest compostable leftovers and half fill the pipe. Don't forget to push it all in with a stick to really get it compact.MIx in some soil every 5cm. You could also put some worms in there
Step 5: Add More Soil
Just add more soil and tap every now and then to keep it all moving downwards and compacting
Step 6: Add Plants and Guide
Add you seedlings and water . This method will reduce slags and pests, save water and help your plants grow using organic decomposing power juice in their own pipe. Did i mention no back breaking bending over to pick fruit. In this example i grew tomatoes and used the peg to guide then downwards to avoid the risk of snapping later. You can grow anything at any height in any space and even have climbers like sweet peas climbing up the sides if its not a tumbling plant like strawberry or tomato . I have also grown flowers on the ground . Another good thing is that in the winter ,even with snow the veg is kept off the ground and with a gloche or glass jars you can protect the veg and the rising temperature from the compost will keep it warm. Enjoy
Step 7: Take It to the Next Level
In the last picture i added some drip irrigation system too
