Introduction: How to Hack Windows XP-8.1
Well what are you waiting for?!?! ITS NOT ON THIS PAGE --->
Step 1: Getting Into the System
First restart the PC. While it is starting, abruptly turn it off and back on again. This will (should) display a menu consisting of two options, "Launch Startup Repair (recommended)" and "Start Windows Normally"; select the first one by pressing Enter/Return.
Step 2: Almost There...
The screen will say "Windows is loading files" or something like that right before the Startup Repair begins. After approximately 10 minuets, another dialogue box appears, asking whether you would like to send a report of the problem. Click on the bottom button, right next to "View problem details." After that, scroll down to the bottom text file, and open it. Next, click File (top right corner), Open, and then "Local Disk" (Drive D:). Look for Windows. Scroll down until you find System 32 (and make sure you are looking in All Files, not just text ones) and click on it. Look for, (or type in the search query) "sethc" and rename it to something else. After that, find the Command Prompt (CMD) and copy/paste it next to the previous "sethc." Now rename the Command Prompt shortcut to sethc. close the two boxes, don;t send an error report, and click on "Finish" on the Startup Repair. The computer should now power down.
Step 3: Last Step
Back on the login screen, enable Sticky Keys by tapping shift five times in a row. The Command Prompt appears!! In CMD, type type following: "net user [username] *", replacing '[username]' with the one your locked out of. You can now change the password!!!
