Introduction: How to Hack and Get HBC & USBLoader GX on 4.3
Hello! This is a guide for all you people who have been getting errors and other stuff while trying to hack their 4.3 Wiis. This method is very easy and it works if you follow all instructions CAREFULLY! So lets get started!
Step 1: Getting the HBC
OK, so first of all you need to have either LEGO Indiana Jones or Super Smash Bros. Brawl. Once you have either of these games, follow the steps below:
-------Indiana Pwns---------
READ : If you have any current save files for LEGO Indiana Jones, you must DELETE them!!!!!
1. Download the Indiana Pwns hack from the WiiBrew wiki: http://wiibrew.org/wiki/Indiana_Pwns
2. Copy the "private" folder to the root of an empty SD card. (note: If your SD card comes with a "private" folder, rename it to "privateold")
3. Insert your SD card into your Wii.
4. Go to "Settings" and navigate to "Save Data".
5. Under the "SD Card" tab, you should find 3 save files. Copy the file that corresponds to your System Region. (Click it and press "Copy")
6. Load up LEGO Indiana Jones.
7. Load the first save file (It should be the only one there).
8. Go outside to the courtyard.
9. Head up to the art room.
10. Go to the left character editor and select it.
11. Go left twice to the icon of two silhouettes.
12. Select it and the HackMii Installer should run.
13. Install everything BUT BootMii!
------Smash Stack------
READ : If you have made any custom stages, you must DELETE them all!!!!! This includes the sample stage that comes with the game!!!!!!
1. Download the Smash Stack hack from the WiiBrew wiki: http://wiibrew.org/wiki/Smash_Stack
4. Load up SSBB.
5. From the main menu, select "Vault".
6. Select "Stage Builder".
7. The HackMii Installer should run.
8. Install everything BUT BootMii!
Step 2: Getting USBLoader GX
Next, I am going to show you how to install USBLoader GX:
------USBLoader GX------
1. Download the ModMii file pack here: http://www.mediafire.com/?y6k6cz6md3meeai
2. Turn off your Wii and remove the SD card.
3. Delete everything off the card.
4. Copy the entire file pack to the SD card root.
5. Insert the card back in your Wii.
6. Turn it on and load up the Homebrew Channel.
7. Press + on the remote and select Load BootMii.
8. Multi Mod Manager should load.
9. From the menu, select "WAD Manager"
10. Press 1, then A on the remote to install all WADs.
11. This may take a while, so wait.
12. Once its done, restart your Wii.
13. You should have the USBLoader GX Channel on your menu!
Next step will show you how to install games on a hard drive!
Step 3: Installing Games to a Hard Drive
Now, I'll show you how to install games to a hard drive!
------Installing Games------
1. Plug in your hard drive.
2. Download an ISO file from any torrent site. Just search for the game you want.
3. Once you have an ISO, load up WBFS Manager 3.0. (You can google it to download)
4. Select your drive letter from the drop-down box in the top-left corner.
5. Click "Format".
6. Under the box on the right-hand side, select "Browse..."
7. Select your game ISO.
8. Wait.
9. It should pop up in the box. (If it doesn't, it's a corrupt ISO. Download a new one.)
10. Select "Add to Drive".
11. You're done! Now plug in your hard drive into the SECOND USB port on the back of the Wii.
12. Load up USBLoader GX.
13. Done!
Now you can happily play free Wii game!!!!!!!!XD!!!!!!!!
12 Comments
12 years ago on Step 3
How do you get USB Loader GX to run on 4.3?
Reply 10 years ago on Step 3
Do the following to install USBloader GX but with the existing files you download from this tutorial and it is recommended that you region free your wii in order to play multiple-region games:
REGION FREE
1.Select Priiloader when you're at the hbc menu. Press +/A to install. Once it finishes the homebrew channel should load. Turn off the Wii after this.
* If the Wii freezes don't panic, it's normal, just hold the power button for 10 seconds to shut it off.
2.Once the Wii is off, is time to turn it back on. But this time, HOLD THE RESET BUTTON, and press the power button, Priiloader will load.
* If MMM loads when the Wii boots, delete the bootmii folder from your sd card. (ONLY IF MMM BOOT IN STARTUP)
3.Once Priiloader loaded, do the following steps:
- Select "System Menu Hacks"- Press A
- Enable the following hacks: "Block Disk Updates", "Block Online Updates", "Remove Diagnostic Disc Check", "Move Disc Channel"
- Select Save settings -Press A
- Press B to go back to the main screen
- select "load/install"
- Install USBLoaderCFG_Forwarder.dol
Thanks, but I ended up downgrading to 4.2 about a year ago and doing it.
That's good to hear. At least you got it running.
Has anyone got it working with this tutorial? I used letterbomb does that make any difference?
10 years ago on Step 2
You just made a hard process a easy one!! Thanks!
11 years ago on Introduction
cod BLACK OPS freezes while loading from usb. Any ideas?
I inherited a Wii with an external hard drive full of games and it uses usb loader gx to play everything on it. I just installed the hackmii installer on my 4.3 wii that I've had sitting around her for a while. I want to have all the same homebrew apps as the working one. Will I be able to clone the existing external drive to another? Or once I have everything set up on my other Wii can I just plug in the external drive, click on the USB loader channel and start playing?
12 years ago on Introduction
how do i stop it from loading the thing when i boot up the wii after i install it?
can this usb loader used on any version of the wii?
Hahaha, I found your instructable!!!!
Don't say my name! I mean it!!
