How to Load Film Into a 35mm Camera
341,523
31
51
Introduction: How to Load Film Into a 35mm Camera
This provides information on loading film and adjusting the main settings on a 35mm camera.
Step 1:
Locate the Rewind Knob, on the left side of the camera, and pull up until the back of the camera opens.
Step 2:
Cut a Leader for your film to load into the Take-Up Spool. The leader must be approximately 22mm to fit into spool.
Step 3:
Place the film into the left side of the camera. Push the Rewind Knob down to create a snug fit on the film after it is placed into the pocket.
Step 4:
Pull the leader of film over to the Take-Up Spool. Insert the narrow end of the film leader into the slot. Hold the spool steady with one hand and push the film deep inside until film is way inside spool or comes out the other side.
Step 5:
Make sure the teeth are properly placed on both sides of the film. Use the rewind knob to take in any slack in the film, tighten the film to the camera. Then close the back of the camera and use the film advance to wind the film.
Step 6:
Take 3 pictures. If the film has been loaded properly the rewind knob will turn ever time you crank the film advance lever. If not, make sure the slack has been taken out of the film by retightening the film to the camera. Make sure you take at least 2 pictures to clear out the exposed film and start with fresh film. Once you see the number 1 in the window, you are ready to take pictures.
Step 7:
Now its time to set your ISO Film Speed. To set film speed, gently lift up the ISO speed ring and turn it to your desired ISO speed shown in the window. (this should rotate the numbers on the INSIDE window on the ring)
Step 8:
To set Shutter Speed, rotate the shutter speed ring to desired shutter speed. The shutter controls the length of exposure, on this camera, the higher the number, the less the exposure time. (this should rotate the numbers on the OUTSIDE of the ring)
Step 9:
To set the aperture, turn the aperture ring to desired aperture. The larger the aperture number, the smaller the aperture opening will be and less the light will be transmitted to the film. (the dial closest to the camera)
Step 10:
This camera has a built in meter. When you press the shutter release button down about one third of the way, you will activate the meter. While the meter is activated, rotate the shutter speed dial or the aperture ring until only the green o LED is lit. when you see the red + LED light, this means your subject is too bright. To fix this, change to a higher shutter speed or aperture. When you see the red – LED light, this means your subject is too dark. Change to a lower shutter speed or aperture. The goal is to achieve the green o LED light for best results.
Step 11:
To set a timer, push down on the self-timer lever until it stops. When you are ready to take the photo, push the shutter release button completely to activate the timer. The photo will be taken in 10 seconds. (the length of the timer could depend on the make and model of the camera)
Step 12:
Once you have completed the roll of film, you must rewind it back into the canister. To rewind your film, press the film release button on the bottom of the camera. Fold out the film rewind crank and turn it in the direction of the arrow until you feel no more tension on the knob.
Step 13:
Pull up on the film rewind knob until the back cover of the camera opens. The film should be rolled back inside the film canister and it is now ready to be developed.
Be the First to Share
    • Reuse Challenge
      Reuse Challenge
    • Metal Contest
      Metal Contest
    • Lamps Challenge
      Lamps Challenge
    51 Comments
    xinyi_ye
    xinyi_ye
    Question 2 years ago on Step 4
    hi i realized that i loaded the film over (with the curve) the take up spool and not under, what’s the difference and how can i fix this. can i just open it and reload it??
    Lethawalter
    Lethawalter
    Question 3 years ago on Step 5
    I am not able to advance the fil! Does it have to be manually rolled further than one time around?
    This camera was bought at a 2nd hand shop! Maybe I need to take it to a shop to have reconditioned?
    sasghar
    sasghar
    10 years ago on Introduction
    Nice information, many thanks to the author. It is incomprehensible to me now, but in general, the usefulness and significance is overwhelming. Thanks again and good luck..
    Squidoo Lens Creation
    sasghar
    sasghar
    The topic that your blog deals with demands loads of research. Thanks to you who has provided the intricate information in simple words.
    Submit Article
    sasghar
    sasghar
    Kodak aren't the only firm who make film, let alone 35mm film - arguably the most ubiquitous format going since at least the 1980s. Fujifilm and Ilford Photo are both large players in the film game and aren't showing any signs of letting up just yet, and Eastern European manufacturers like Foma and Efke show it's possible to make it work at a small scale.
    SEO Content Strategy
    uafzal1
    uafzal1
    On the other side, digital imaging and "tweaking" with the help of software can be as artistic as analog darkroom art, but takes much less effort in the beginning, so that people become lazy, sloppy and careless; always wanting "instant gratification". I have taught photography with BOTH formats, and always have detected that people that start with Digital cameras tend to shoot THOUSANDS of frames swiftly...
    Coach Hire London
    jrfrank
    jrfrank
    Thanks Emilee for a great instructible! It inspired me to get my Nikon F3 going and shooting . Loaded some Fuji 200 neg film and getting the film developed and put on CD at a local store for $2.49. Poor man's digital SLR!
    EdRothe
    EdRothe
    I've got a better idea. Put it on your antique shelf and go get a digital camera. Kodak just went bankrupt because few people are buying film anymore. It wont be very long before 35 mm film is no longer available or is too expensive if you can find it at all. IMHO,,, ;-)
    amclaussen
    amclaussen
    You miss it completely... Film Photography is an art in itself. If you are now goint to comment that everything "digital" is better just because it is much more recent, you are not seeing the point. And your other comment on 12" Vinyl records also reflect your lack of knowledge and understanding. Nobody claims that digital sound or photogtaphy is not VERY convenient, but that's not the point. And truly knowledgeable and respectable audiophiles consistently find some elusive qualities in the old vinyl LP, so that you can find A LOT of new and recently designed ANALOG audio at expensive prices. Of course, to be appreciated, it takes some serious efforts. It is like fine wines; not every person likes them (or is capable of appreciating them), it takes dedication, effort and some study. Digital is capable of high quality imaging, but to equal the quality of a good old 35mm camera and best quality film, takes quite a bit of money nowadays. On the other side, digital imaging and "tweaking" with the help of software can be as artistic as analog darkroom art, but takes much less effort in the beginning, so that people become lazy, sloppy and careless; always wanting "instant gratification". I have taught photography with BOTH formats, and always have detected that people that start with Digital cameras tend to shoot THOUSANDS of frames swiftly... to end erasing most of them and NOT improving the least bit... because is all too easy to just keep pressing buttons! On the other side, having to wisely use the expensive (in time and cost) film, really teaches them to become intelligent picture takers.  Think about it.  Amclaussen.
    EdRothe
    EdRothe
    Alright already, I am properly chastised! How about if you instruct us all on the appreciation of fine wines on Instructables, Professor Amclaussen?
    I do agree with your point "shoot THOUSANDS of [digital] frames swiftly" (I see it constantly from my grandchildren on Facebook, for example). But that is another argument, not one that will forestall the inevitable movement to the digital medium for even the most serious photographer as the techniques are developed. (IMHO, of course.)
    BTW, "truly knowledgeable and respectable audiophiles consistently find some elusive qualities in the old vinyl LP" is pedantic nonsense. If the CD had been designed with a sufficiently small quantization (more bits per sample) there would have been no issue for the self appointed " knowledgeable and respectable" experts to preach to us about.
    amclaussen
    amclaussen
    Well, your comment suggesting to "Put it on your antique shelf and go get a digital camera"  was not nice,to begin with.  It meant throwing a perfectly good camera to the thrashcan or forget it on a shelf.  That's a shame. (and goes against the nature of Instructables, no less). I wasn't "preaching" at all, but inviting to be more appreciative.
    My comment was the result of your quick and coarse disqualification of the true value of the film cameras. I will invite you in the most respectful way, to hold a good 35mm camera in your hands, and then take a recent equivalent Digital DSLR...  Does it have the same precise, solid feel? NO!  Does it perform always better? Nope!  Will it endure for another 30 years? Absolutely NO !    See... while newer cameras have numerous aids, options, settings and bells and whistles (too many), the BASIC construction quality has been lost.  You need to pay several times as much in order to get today's best quality lenses and camera bodies, just to approach the construction quality of the cameras available to the public in the 80's !
    The thing here is that THERE IS a sizeable movement going to old fashioned film photography, as well as another equally veritable group of people investing time and money, and specially dedication to the analog and Vinyl record reproduction.  Remember when the first Compact-Disc players started to appear back in 1983?, well  I clearly remember most (about 99%) of people declared the LP dead forever, and claimed that the newly developed CD was absolutely, completely "perfect"... and just a few found some objectionable artifacts in them.  Some years later the same folks that had claimed the initial CD's started to accept that the first generation players (and many of the second generation too) were awful sounding.  The fact is that NO CD is "perfect" even today, after many refinements.  Latest designs of Digital Audio formats use up to 24 Bits at 192 KHz instead of the 16 bit 44.1 KHz of the CD... But it is still open to debate if it is really enough for high quality reproduction.
    The fact is: "If CD would have been designed..."    -But it WASN'T!!!
     The same applies to Digital Photography today, it is still far from "perfect", and every year manufacturers push quality just a little bit higher, in order to make the most money in the long run.
    Now, if you compare the true optical quality of the SLR lenses available in 1980 to the lenses sold today, you would be surprised that in MOST cases, the old lenses measure better, image better, and render beautiful pictures with old "outdated" film!
    If an Instructable verses on the RESCUE of a perfectly good old technology, that somehow has not been completely surpassed by newer technologies (in some respects), FINE !
    Let people enjoy old cameras and lenses, learn darkroom film and print processing, and get some real traditional artistic ablilities that come naturally with those old techniques.  Nobody will doubt that Digital Photo is here to stay, and has reached a very high degree of quality, but it is not perfect yet, and instead of a competition between two aproaches, it is more the combination of both worlds that is the most desirable attitude.
    The example about wines is just that: an example. The objective was to show that everything needs a little appreciation. Not to offend or disturb anyone.  Another good example is the irrefutable return of the classic MECHANICAL wrist watches (mabye never as presice as time keeping pieces as the electronic ones, but as a tribute to appreciation. Not meant to be worn at all times, but for special occasions. Let's be constructive and appreciative.  Let's have many more Instructables like this, specially to show too young persons the beauty lying in older designs, arts and crafts.
    Have a nice day.
    jb17kx
    jb17kx
    In my mind, now is a better time than ever to lend a helping hand to keep one of modern history's most influential art techniques alive. Prices for used equipment spent most of the last ten years tumbling but is now, if anything, on the up again. Professional 35mm camera systems (not the incredibly cheap one used for this instructable) sell used today for a fraction of their list price.
    A Nikon F4S, for example, sold new in 1988 for circa $2500 (before inflation) but can be had today, in great nick and with a tonne of life left in it, for less than $300.
    Libahunt
    Libahunt
    Maybe then it is the last best time to take up the hobby while it's still available?
    35mm can go out of use, but film in general will not. The analog-natural is beauty in itself.
    EdRothe
    EdRothe
    OK, I'll concede the point. There are still a few folks around who swear by 12" vinyl records, as well. To each his own.
    im3733
    im3733
    Not to mention, keep it in good enough shape, pass it down for a generation or two, and you've got yourself an antique heirloom!
    amclaussen
    amclaussen
    10 years ago on Step 8
    Emilee: It would be helpful to include the reason for setting the shutter speed in this step, also in the next one for the aperture. The rule of thumb that I have used for years to easy the learning of the exposure controls is the following: The proper exposure settings for the film are like the act of trying to fill a glass of water to a mark in the middle...  you can open the fawcett to a trickle, and wait for hours to reach the level mark in the middle of the drinking glass; or open the fawcett wide open for a couple of seconds!  The analogy is that shutter speed is akin to the time the fawcett will let the water into the glass, while the Diaphragm or lens opening is akin to how far you open the valve.  The size of the glass would then be akin to the Film sensitivity or ASA (now ISO).
    Thanks for your nice Instructable, amclaussen
