Introduction: How to Make a Audio CD Player From Old Cdrom
Hello Friends this is my First Project On Instructable.
In It I Will Show You How To Make A Cd Player from Old Cd Rom.
IT IS VERY SIMPLE EASY AND CHEAP PROJECT EVEN A 8-10 YEAR OLD CHILD CAN MAKE IT.
I HAVE MAKE IT FROM OLD PARTS FROM OLD PCS LIKE PENTIUM 1 WHICH HAVE NO LONGER USEFUL.
TRY IT ON YOUR OWN RESPONSIBLITY.......
Step 1: COMPONENTS of Player for Indoor Use
The Things That You Will Need are
1. Old Cdrom/Dvd rom.
2.Stereo Lead for amplifier and cdrom
3.A old Pentium 1 Power Supply.(if don't have)use Pentium 3 or 4 Power Supply
4.And Last Thing Audio Cds.....
5.Old Amplifier And Speakers.
Step 2: COMPONENTS of Cd Player (For Car Use Only)
2.Stereo Lead for amplifier and cdrom.
3.12 volt to 5v converter.
4.Old Pc Power Supply Connectors.
5.Amplifier or Amp And Some Speakers.
6.Some Audio Cds.
Step 3: Lets Begin(indoor Use Only)
Firstly Take A Cd Rom or DVD Rom I Prefered Cd Rom is Best For Testing.
Now If You Are Using Pentium I Power Supply.
Short Last Pin of P9 And First Pin of P8 Ashown in Pic
Step 4: Power Supply(Indore Use Only)
Just insert the power cable in power jack of cd rom and Insert power cable in power supply.
Power on the Power supply and insert the audio cd in cd rom
Step 5: Amplifier(Indoor Use Only)
Use A Stereo cable in the output of Cd rom and the other end to the input or Line in of Amplifier.
Thats All Done
HAVE FUN
Step 6: Power Supply(Car Use Only)
Note Here Power Supply is attained from car so you need a 12v-5v converter and a simply 12v-12v.
Because Power Supply from Pc Provides 5 and 12 volts
Red And Black Wires Provides 12v
and Yellow and Black Provides 5v
Step 7: Amplifier(Car Use Only)
If you Have amplifier in your car that good if not you have to arrange it
just take a stereo lead and connect it to the output of cd rom to input or line in of amplifier.
And Put the power cord at the back of cd rom and insert the audio cds,
Now Thats all Enjoy The Music
Step 8: NOTE
THIS AUDIO CD PLAYER IS COMPLETELY TESTED AND I HAVE TEST IT.
BUT DO IT ON YOUR OWN RESPONSIBLITY.
BE SAFE
Dead Computer Contest
21 Comments
8 years ago on Introduction
post the video
10 years ago on Introduction
Great job and thanks for sharing! You have a brilliant future ahead. Thanks again.
Thanks For your appericiation.
12 years ago on Step 3
why are you shorting out parts of the supply, those old AT class power supplies will turn on without being connected, as they are not "intelligent" and only controlled by a switch which is connected to mains
because these psu r dumb devices they require some dummy load
u can use a resistor as well or simply do as i did it.
At Supply and Atx both require Some Dummy Load to Go to Power on state
For Atx Simply Short Green and Black Connector in 20 or 24 pin power jack
For At Refer to user manuals
Reply 12 years ago on Introduction
Brother i have tried this without shorting the pin no last of p9 and first pin p8 without shorting there will be a Short circuit and if u have circuit brackers installed in ur home the will trip just check and reply.
Actually i am shorting pin no last of p9 and first pin p8 that power supply understood that a mother board is connected to it and you could use it as a supply.
OK
you must have a "special" one from a name brand computer or something, I have 1 now on my bench as a gp power supply and I have never had one trip a breaker (unless I got the main's switch wired up backwards ... the 1 time I did that it wasnt pretty)
May Be U are Right But i have 4 or five AT power supplies all have same procedure to make them work.
NOTE THAT I AM TALKING ABOUT PENTIUM 1 OR AT POWER SUPPLY NO ATX CHECK THE SCHEMATICS OF P1 MOTHER BOARD THE LAST PIN OF P9 AND FIRST PIN OF P8 ARE SHORT.
if u want to check my words just pick a PENTIUM 1 mother board and check the last pin of p9 and first pin of p8
simply check the continuty
ok that should solve ur problem
THANKS FOR UR COMMENTS
well I dont have a board to check, and the ones I am referring to (AT class) all used the same power supply
heh mine is even the old school style with the big red paddle switch, its powered a 368, a couple 486's, pentiums and 2 k6/2's
erm in one of your steps you said red and black is 12V and yellow and black is 5V, now i thought yellow was 12V-+, red is 5V-+, and black is ground.
good idea but i just a pioneer headunit indoors using a PC PSU
hahah u realize my mistake.Thanks for ur correction.
11 years ago on Step 4
it is nice but my dvd rom does not has any stero jack connector in it what to do please tell me?
so thats not a problem.Simply ur dvd has audio output on the back
for more info refer to product manual of ur manufacturer.
Reply 11 years ago on Step 4
use back side audio output for dvd roms
i will upload stand alone dvd player very soon so w8 for it.
you can also google "How to make a stand alone dvd player"
Thanks for your intrest.
made one myself and its great :) you can check it out here>>> http://www.youtube.com/watch?v=S4wQFvEcnY0
but i was wondering if you can make one out of a cd-r drive or know where i can find some information because i cant figure it out..
thanks
Thanks for ur intrest.
12 years ago on Step 5
Your pictures & comments leave alot to be desired...
did something like that in the past, with a switch soldered to the psu, but one thing bothers me, how do you start the music or skip the songs? mine got 3 buttons on the front. (btw, I used the back audio outputs instead of front ones)
u are right this one has no buttons so the once the cd is inserted it will start to and if u eject it will stop.
no forward reverse.
if u want these options simply take a cd rom that have forward and reverse option like Creative infra 52x.
i am using it and it works great
THANKS FO UR COMMENTs
This is Simply a Prototype and u can use different verity of cd roms and power supplies.i am now doing experiment on CREATIVE INFRA 52X.and it doing fine.Thats True U can take output from both back and front.Back Pannel Called DIGITAL AUDIO.But it Simpler Than Having Solder 4 wires to A Female stero Socket.
instructables is all about the projects that common people can make.
So I Hope U Got the answer
