How to Make a Duct Tape Wallet
Intro: How to Make a Duct Tape Wallet
Everybody needs a wallet, right? If you have a taste for the unconventional, or you're simply a stubborn do-it-yourselfer, then whip out that roll of duct tape and make your own wallet!
What you'll need:
- Duct Tape (duh)
- a ruler/protractor
- a knife (or other cutting utensil, preferably not scissors)
- work space w/ flat surface
What you'll need:
- Duct Tape (duh)
STEP 1: Step 1
Rip a strip of tape at least 10 inches (295 mm) in length and place it sticky side up on your working surface.
Then, rip a second piece of equal length and place sticky side down halfway over the first strip. Fold the rest of the strip facing up over the second strip.
STEP 2: Step 2
Flip over the two strips and place a third strip sticky side down covering the remaining sticky part of the second strip. Flip the sheet again and continue extending the size of the sheet until you've created a large sheet of duct tape that is 8.5 inches (215 mm) by 7 inches (175 mm).
STEP 3: Step 3
Trim all the edges.
STEP 4: Step 4
Fold the wallet in half and tape 3 sides (bottom and two sides) to create a large pocket to hold bills.
STEP 5: Step 5
To create credit or business card pockets, make another sheet that's 4 by 3.5 inches (100 mm by 90 mm).
STEP 6: Step 6
Fold 1.5 inches (40 mm) over. To create two more pockets, repeat the step above and then tape the two pieces together, taping the second pocket a little lower on top of the first piece.
STEP 7: Step 7
Tape the edges of the pockets and then tape the whole piece to the large pocket. To create another pocket, leave the inside part untaped.
STEP 8: Step 8
Make a sheet of tape (as in the first step) larger than your ID card. Cut the sheet so that there is a 5 mm frame (big enough so you can see your picture and info, but small enough so the ID can't fall through the opening). Now trim the outside so it is slightly larger in all directions than your ID. Tape three sides of this window to the inside of your wallet, or on top of the credit card holder. It'll take a some trial and error to get it right, but it will be a great addition to the wallet. When you're done, the ID should be able to slide into the untaped side of the holder, and once in, not fall through the open window.
Tape the completed pocket to the large pocket and again, you can create an extra pocket if you wish by leaving the inside part untaped.
STEP 9: Step 9
Put your money, ID, and cards in your wallet and go show off your new creation!
8 Comments
Craftsman1997 7 years ago
hawk45 8 years ago
Nice! great tut btw is that a leatherman wingman?
BarreymisterP 8 years ago
Awesome and cool
Daze-Heller 9 years ago
Thank you! This was a good help on getting me started. I have figured out a way to use less tape on the pockets, but it was a good start to see how you did it. I had a lot of fun!
Michaela 11 8 years ago
What is the way that you can use less duct tape on the pockets?
NickL11 9 years ago
this didn't help at all
Is there something that I can help explain?
NoahB4 9 years ago
fun
