Introduction: How to Make a House in Minecraft
Step 1: Make a Base Out of Your Material
I used cobblestone in this case.
Step 2: Build the Structure's Pillars
I did all the pillars 4 blocks high. Do count the block on the base as one.
Step 3: Build Another Base on the Top
It has to match the one on the bottom.
Step 4: Build the Walls With Another Material
I did not fill in the inside of the house. And I prefer wood for this technique.
Step 5: Based on Your Base, Find the Middle and Make a Doorway
Try not to make it odd looking. If the base is in width on an odd number, make a single doorway.
Step 6: Go Inside
(At the bottom I used another material for the floor.)
Step 7: Add Light
Use torches or glowstone.
Step 8: (Go Outside) Add Doors.
Place them depending on how many door holes you have.
Step 9: Add a Mini Staircase
Add the stairs depending on how many doors you have. (I have 2).
Step 10: There! Your Done!
It isn't that bad for a mine-crafter. Try making a roof.
