Introduction: How to Make a Necklace
Have you ever wanted to make your own jewelry, but you didn't know how?
This instructable will tell you how to make your own beaded necklace
Step 1: Measure
First, you will need to measure the length of the string. You can use a ruler or a tape measure
Step 2: Cut
After measuring, cut the desired length. Please note that you will need an extra inch for the knot at the end
Step 3: Pendant
Find the middle of the string and put the biggest bead possible
As your pendant. You do not need to do this step
Step 4: Start
Now you have to find the second biggest bead and place two of them on either side of the pendant
Step 5: More Beads
Add the third biggest bead and string it next to the second biggest beads
Step 6: More and More Beads
Find the smallest bead possible and put 3 different colors on a row next to the third smallest beads
Step 7: More and More and More Beads
Add 4 small beads (different from the smallest bead) next to the smallest beads
Step 8: Almost Ready
Add four of the flattest beads next to the small beads.
Step 9: More and More and More and More and More Beads
Now add two of the the second biggest bead again (the one next to the pendant)
Step 10: No More Beads
Add the second flattest bead 4 times
Step 11: Last Step
Add the 2nd biggest bead until the necklace is finished
