Introduction: How to Make a Nuka Grenade
Ever Have Troubles In The Wasteland,Well Now You Don't Need To Worry About Getting Killed By Super mutants,Feral Ghouls,Raiders,Or Even Enclave Soldiers With My How To Make A Nuka Grenade Guide And You Don't Even Need A Schematics Plan,No Caps Needed!!!!
Step 1: What You Will Need
First You Will Need The Following Items-
-Tin Can
-Sharpie Marker
-White Paint
-Black And White Wires
-Super Glue
-Pliers Or Wire Cutter
-Screw Or Nail
-Three Ring Shape Wire Connector Tops PAINT THEM WHITE!!!
-Coat Hanger Bar (Metal)
-Masking Tape (Vanilla Color)
See The Photo On For More Information
-Tin Can
-Sharpie Marker
-White Paint
-Super Glue
-Screw Or Nail
Step 2: Punching Holes
First Punch Three Holes In The Bottom Of The Can.
You Can Use A Screwdriver And Apply Pressure On The Spot
You Want To Punch A Hole In
Step 3: Punch Holes on the Can's Side
Glue The Two Caps On The Holes On The Side Of The Can,The Other One Will Be Used Later.
Step 4: Put Masking Tape to Use
Write Radiation On The Front Of The Can.
Then Write Danger On The Back.
(On The Masking Tape)
(Write Them A Little Hardcore)
Step 5: Put Wires to Use
Wrap The Wires On The Inside So The Wires Cant Be Pulled Out.
Do The Same Thing With The Red Wires
Step 6: Use That Spare Cap
Remember That Last Cap I Was Talking About Earlier,
Well put it to use!!!Glue the cap on the Nearest Hole Near The Edge
The Two Holes In The Middle Of The Can Will Be For The Wires
Get A Nail Or A Screw And Use That Coat Hanger Bar And Wrap It Around The Nail
Bend The Coat Hanger Bar After It Has Been Put In Place,It Might Break So When Done Put An Additional Coat Of Super Glue.
You Will Now Your Final Result!!!Now Get Your Super Glue And Put Glue On And In And Around The Nail And Cap So The Handle Wont Break That Easy
Step 7: Seal That Sucker Up!!!
Before You Do Anything Maybe....Show Off,Pretend Or Just To Keep,Seal The Lid With Super Glue And Then Keep Can Under Pressure So Lid Wont Pop Open While Drying.You Can Also Use Hot Glue Or Anything That Will Keep That Sucker Closed!!!
Step 8: CONGRATULATIONS WASTELAND DWELLER!!!
Congratulations Fellow Wasteland Dweller You Have Made Your Own Nuka Grenade
Now You Can Roam The Wastelands Without Worrying About A Pack Of Raiders Jumping
Out Of The Ruins Or Getting Eaten By Feral Ghouls When Roaming The Subway Stations
When You Can Just.....BLOW E'M UP!!!!!Stay Safe Out There In Those Ruins!!!!
