Introduction: How to Make a Origami Paper Bomb
This instructable will show you how to make a origami paper bomb.There are lots of things you can do with the paper bomb so now let's go make it.
Step 1: Getting the Materials
You are going to need a 8 1/2 x11 piece of paper or a square piece of paper and a pair of scissors.
Step 2: Getting Started
If you have an 8 1/2 x11 piece of paper then you will have to do this step.Now take one corner of the paper and fold it down until it has a pointy tip at the other top corner and cut the bottom part.
Step 3: Folding Starts
Now if you have a square piece of paper you will have to take one corner and fold it to the bottom corner and do the same thing to the other corner and unfold.Take the top side and fold it down.
Step 4: Making the Shape
Now put one of your fingers in the middle,then open one side and take the top crease and bring it to the middle and flatten it.Do the same to the other side.Now if you look in the middle there should be 2 lairs,take 1 corner of the first lair and fold it to the top,now do the same to the other corners.
Step 5: Locking in Some Flaps
Fold 1 lair of the side corners to the middle and do the same to the other side.Now at the top there should be two flaps on each side,then fold it to the corner and fold it again on that line then unfold 1 time and open a pocket form that corner you folded to the middle and stick in the flap in it and do the same to both sides.
Step 6: The Finishing Fold
Now pick it up and open its side and fold it and do it to the other side but make sure the corners that were folded to the middle does not get ruined and turn it and at the tip there should be a hole and that's where you blow in it.I hope you enjoy playing with it and don't forget to comment if you liked it! :)
