Introduction: How to Make a Retro Wall Clock
About: Come spend some time in the shop. I'm a hobbyist woodworker and professional computer geek in Northern California. I guess my projects will vary widely, and I have no clue what I plan to make next...
I recently melted down some milk jugs and bottle tops to make a colorful block of material. I began pondering what I could do with it! This was the first I idea that grabbed me. A HDPE wall clock!
Step 1: Begining
I started by cutting my panel to a pleasing shape at the band saw. The design was suppose to look like those 50's and 60's retro signs. Think the maple coupled with the bright colors of the HDPE sorta called for it
I thed drilled 1" holes at the 12, 3, 6 & 9 O'clock positions.
Step 2: Lathe
Then it was off to the lathe to spin up my block and get it into round
It turned very nicely and was a pleasure to work with! I then snuck up on 1" so that it would fit correctly in the wall clock!
Step 3: Adding Inlay
Next was the tricky bit! Since you cannot glue HDPE to wood (the glue will not adhere) you need to attach it with metal fasteners. which I did.
I then melted a thin slice on top of that to hide the screw from view.
This is were things got complicated. The wood was burning during the melting process.
But when sanding out the burns I was sanding the HDPE enough to show the screw. More melting, then more sanding, then more melting.... it was a vicious circle and I was getting frustrated!
Step 4: Completed
So I did as best I could and moved on... I drilled then chiseled an opening for the clock movement, added a poly finish and called it done.
It is not what I had in my head, but still not a horrible project. Next time? I'd just screw in the HDPE from the back and plug those hole with a dowel, instead of trying to be all clever....
