Introduction: How to Make a Secret Base: Part 3!
Hello minecraft players! I know it doesn't look secret, but getting in is a secret to you and your teammates! Forget digging a hole in the ground and covering it! This base floats in the air! Other players will be dazzled on how you just dissapear! Alright, enough yakking, let's begin!
Step 1: Materials
This ingenious base can be built with just with nether quartz block, quartz slab, rails, and minecarts.
Step 2: Floating Block
Build a tower about 7 blocks high. Then break all the blocks except the very top one.
Step 3: Slab
Place a slab next to the floating block. Then, put 2 more slabs on top of the first.
Step 4: Minecart
place a minecart on top of the 3 slabs. Then make a floor starting by the quartz block. Place more quartz block around the minecart so it won't move away from the slab.
Step 5: Viola!
Here's the secret: when you stand on the ground, search for the minecart by looking around the bottom of the base. You'll have it when a message that says "ride" appears. Then just hold your finger on the right spot until you teleport to the minecart. If you want, you could make it go higher. There you go! If you like this and want to hold on to it later, please favorite. If you have any questions or suggestions, leave them in the comments. If you want to stay in touch, please follow!
