Introduction: How to Make a Triple Single
This triple single is a simple bracelet moving on from the fishtail and single! You will have a lot of fun making this and I hope you think it is fantastic!
Step 1: Gather Your Material
You will need...
Loom (any I am using a DIY loom)
A hook
S or C clips
Loom Bands
Step 2: Placing the First Bands
First turn your loom around and place the bands like a single bracelet but going in a straight line.
Step 3: Adding the Holding Bands
to add the holding bands just add triangles all the way down except the one on the very top as shown (sorry if the pictures are not very clear this time).
Step 4: Hooking the Bands
to hook the bands go inside the bands and hook them to the next peg. At the end check if anything is missed out otherwise it will fall apart.
Step 5: Adding an Extra
To add the last band place the bands on the side to the middle and slip your hook inside all those bands, then place a band on your hook and pull it through then hook the end to the hook (it sounds confusing but not when you actually do it).
Step 6: Taking It Off
To take it off all you have to do is pull slowly, you might need your hands to take it off. When you've took it off it should look like the picture shown above.
Step 7: Finished!
Now you've finished! Just secure a C or S clip on the end and then secure it on the other side! I hope you enjoy it!
