Introduction: How to Make a Vise-grip Slide Hammer
This instructable shows how to make a vise-grip slide hammer. The slide hammer can be used for about anything that you can think of. If you can clamp it with the vise-grips, you will be able to pull what is stuck free.
Step 1: Materials That You Will Need
1. 5" long 2" diameter round stock- mine is P20
2. 16-2mm / 250mm cap head screw
3. Pair of vise-grips
4. 2 16-2mm nuts
5. A center drill
6. 8.5mm drill bit
7. 10-1.5mm tap
8. 5/8 drill bit
9. Tap handle
10. Tap magic cutting fluid
11. Cutting oil
12. Lathe
13. Bench grinder
14. Welder (I use TIG)
15. File
16. 10-1.5 / 25mm cap head screw
Step 2: Face Rough Ends
Chuck the round stock in the lathe and face both ends so that they are true and flat. Use the file to smooth out any burrs.
Step 3: Center Drill
Start your hole for the slide bold through the round stock with a center drill.
Step 4: Drill Hole for Slide Bolt
Use the 5/8 drill but to drill hole through round stock for slide bolt. Be sure to use cutting oil to keep your work piece and drill bit cool. You may also want to drill a medium size pilot hole.
Step 5: Smooth Rough Edges
I use a counter sink bit to smooth out the rough edges and burrs from the hole I just cut for the slide bolt. Be sure to do both ends.
Step 6: Center Drill Slide Bolt
Chuck the 16-2 / 225mm cap head screw in the lathe. Start a hole with a center drill
Step 7: Drill Slide Bolt
Use the 8.5mm drill bit to drill a hole into the bolt. The hole should be about 1.25" deep.
Step 8: Tap Slide Bolt
Use the 10-1.5mm tap, tap handle and tap magic cutting fluid to tap hole in drilled end of slid bolt. Make sure you tap deep enough to shoulder a 25 mm long cap head screw but not too long that you bottom out the tap and rip all the threads out.
Step 9: Join the Slide Hammer and the Slide Bolt
Out the slide handle over the slide bolt and secure with 2 16-2mm nuts. Torque the 2 nuts together at the end if the slide bolt so they don't move.
Step 10: Prep Bolts for Welding
Grind a chamfer on the end of the 10-1.5 / 25mm cap head screw and the bolt from the vise-grips. This allows more weld to penetrate for a stronger bond.
Step 11: Weld Bolts Together
Weld the 10-1.5 / 25mm cap head screw and the bolt from the vise-grips together. I TIG weld everything but MIG or stick will work just fine.
Step 12: Finish
Join the vise-grips and the slide hammer together and your done. You can also make other attachments to go with your slide hammer.
