Introduction: How to Make a Waterbomb
Hey guys this is my tutorial on how to make a waterbomb. If you havent seen my tutorial on the waterbomb base go to my page.
Step 1: Supplies
-Waterbomb base
-Hard surface for folding
Step 2:
Take your waterbomb base and fold one side of the first layer on the base so thst the outside lines line up. Your fold should be along this dotted line.
Step 3:
Repeat Step 2 on front and back of the base and also on left and right until you are left with a diamond.
Step 4:
Fold the side of the first layer over until the point meets the center line in between the two folded up flaps. Repeat on all 4 sides.
Step 5:
If you pinch the folded over flaps we just made you will see a sort of pouch, the top point will be securely tucked away into this pouch so it will not move. Repeat this process on all 4 sides.
Step 6:
On the opposite side of the pouches there will be a small hole. If you blow into this hole the project should inflate into a box.
Step 7:
This Waterbomb can then be filled with water and when held at the bottom can be thrown like a water balloon soaking any victim.
