Introduction: How to Make an Amazing Physics Toy With 3 Balls & a String
This is something I used to have as a child (my parents bought it somewhere), but I never was able to find it. It just disappeared from my life. So I decided to make my own!! I had some bouncy balls lying around, & I asked my parents if they'd take me to Walmart to get some string. I drilled, threaded, tied, & voila - a new toy!! You can do all kinds of tricks with them & I swear it seems like physics in action.
Step 1: What You Need:
Parts for toy:
3 bouncing balls (you can use any ball, as long as you can drill into it)
String with moderate thickness (see pic above)
Tools & parts to help with making process:
Dremel Drill
Drill bit (I used 1/8 inch diameter)
Pliers
Paper clip for "needle"
Step 2: Drilling
Take the Dremel & carefully place it on the center & slowly drill. Once you've gone a little ways (but just enough to where it won't slip), go ahead & drill at a higher speed. Do this to all 3 balls.
Step 3: String
Take a piece of string - good length - & cut it off.
Then, at the end, tie a bowline knot. Instructions: http://www.animatedknots.com/bowline/index.php?Cat...
Once you tie the knot, cut of the excess.
Step 4: Needle & Thread
Take the paperclip, straighten most of it out. There will be 1 end that will be unbent. Why? Well, that's what we'll use to secure the other end of the string on.
So take that string end, & tie it on the bent end of the paperclip. Then take the pliers & smush that part flat (as shown). Now you have a "needle".
Take the needle & thread it through all 3 balls. Now the toy is almost complete.
Step 5: Knot Again (Pun Intended)
After the threading, cut that part off close to the "needle", for it's frayed. Now do the bowline on that end. Just like on step 2. But wait, the project isn't complete!!
What if the toy has too much string? No problem, now you can (almost) carelessly tie the bowline again somewhere along the string. I know, I don't have a pic for that, but I think you know what I'm getting at. If not, I'll go back & add a pic. Keep doing that until desired length, then cut off excess.
Step 6: Finished!!
Congrats, you just made your own cheap, homemade version of Astrojax!! Now sure, this might not work JUST like the real Astrojax, but they come close. They're so awesome & I hope you enjoy them!!
