Introduction: How to Make an "Electronic Warfare" Tail for Your Paper Airplane
This is an "electronic warfare" tail I developed for better stability and lift on paper airplanes.
A tailplane is an important part of most all aircraft. And although some specialized aircraft like flying wings and paper airplanes avoid the requirement of having a tailplane, adding one can make your plane look cooler, and in some cases even improve performance greatly.
Electronic warfare aircraft, like the USAF EF-111A Raven, and the USN/USMC EA-6B Prowler have pods on their tailplanes which house antennae. These pods resemble--looking front-to-back, or vice versa--pine trees.
How cool would it be to have an "electronic warfare" paper airplane? Well, this is how to add this very cool accessory.
To show you how to make this conversion, I will build off of a Super Dart paper airplane to make the 'EF12-1' Super Dart.
Step 1: Materials
Required:
1prebuilt, untaped paper airplane (a Super Dart pictured)
Scissors
Tape
Optional:
Pencil
Step 2: Cutting the Tailplane
It is very important when modifying any aircraft I've posted on Instructables.com, that you do not tape them up prior to the conversion. If you do, you will not be able to equip your paper airplane with an "electronic warfare" tailplane.
To make the tailplane, a simple cut at an obtuse angle torwards the nose of the aircraft. Then reverse the tail through the center of the aircraft to be above the wing. Then fold the plane in half and put it down.
Step 3: Folding the Tailplane
As your plane lies flat, push the top center fold of the fin to the wings' center. Then open it as it was before. Then fold that center fold line down to the wing root as cited in the picture (be sure not to fold the other side in the process). Then open it. Repeat on the other side.
Step 4: Tape the Tail
Tape your aircraft in these 4 places. (Generally, this modification will carry over 3 common places to tape over any aircraft, though there are exceptions).
Tape your Super Dart's nose, rear, and pod together.
After this, your aircraft should appear as it does in the last two pictures.
Step 5: Finished
Your "electronic warfare" pod is now finished. It will now provide your aircraft additional stability and lift.
You can now build fairly asymmetrical aircraft that will still fly straight and far without worry.
Enjoy!
6 Comments
12 years ago on Introduction
step3 is hard to understand
Reply 12 years ago on Introduction
Can you explain so I can make it clearer?
9 years ago on Step 5
i prefer these stuff on planes with wings parallel to the fuselage
Reply 9 years ago on Step 5
As do I; my preference toward wing angles of incidence of zero degrees is one reason why the amount of airplanes I design configured like the Super Dart has dwindled lately.
well u say to fold the paper down and then fold it down again and i do that but then i dont end up with the correct tail. i just a bent stabilizer were the electronic warfare pod should be.
Are you sure you aren't doing both sides' steps on one side?
