Introduction: How to Make Bitchin' Resin Photo Magnets!
Step 1: Materials
Jar lids, spray paint (I like to paint the jar lids so they look pretty), scissors, paint brush, mod podge, Easy Cast clear casting epoxy, glitter, glitter glue, images (these can be photos, magazine images, drawings, whatever!) children's medicine measuring cups, a jar for mixing, a plastic knife, magnets. All these things are things you already own or can be found and purchased at Hobby Lobby.
Step 2: Cut Out Images
After you have spray painted your lids and they are dry and you can no longer see the brand name under the paint you're ready to trace and cut out images. Pick an image you like and place the lid over it. Trace with a sharpie around the lid then cut out your picture.
Step 3: Coating Images With Glue
I cannot emphasize enough how important it is that you completely coat and seal the front, back, and sides of your image. I put two semi thick coats on the from and the back and a good globby coat on the side. Let the glue dry completely.
Step 4: Placing Image Inside Lid
After you have thoroughly covered the front, back, and side of your image and allowed the glue to dry place a dot of glue inside the lid and place your image inside. I like to add another layer of glue once the image is inside paying close attention to the sides.
Step 5: Adding Glitter and Embelishments
After the glue from your last layer has dried you can jazz up your image by place small 3D objects inside, drawing with glitter glue, adding glitter powder and bobble eye etc.
Step 6: It's Time for Resin!
This is super important! You have to measure carefully and add exactly equal amounts of both parts of the epoxy for your project to work. If you do not add equal amounts the resin will never dry and you will have a sticky mess! Measure out both parts and mix them together in a disposable container. It doesn't matter how much you mix as long as both parts are equal. Stir the mixture for one minute clockwise, stop and stir counter clockwise for another full minute and then pour into the jar lids and stop just before you reach the top.
Step 7: Now Watch Them Dry! or Not It Will Take Awhile.
Allow the resin to dry for at least 24 hours on a flat surface where they will not be disturbed. I don't recommend leaving them or making them outside because dust, bugs, leaves, etc will end up in them. After they are dry glue a ceramic magnet to the back and enjoy! These make great personalized homemade gifts!
