Introduction: How to Make Cake Balls
Step 1: Grab Your Ingredients and Supplies!
Ingredients include:
- 1 cup of Water
- 1/3 cup of Vegetable Oil
- 3 Eggs
- Chocolate (or any flavor you prefer)
- Cake Mix
- Frosting
- Chocolate Chips (or any frosting that you would like to cover the balls)
- Decoration Frosting
Supplies include:
- 2 bowls ( a small and a big one)
- Vegetable Oil Spray
- Flour
- Spoon
- Pan (whatever size you would like to use)
- Toothpicks
- Aluminum Foil
- Big tray or Table
Step 2: Mix Your Ingredients!
I like to start by mixing my liquids first, then adding in the flour last. Mix your 3 eggs, vegetable oil and water together in a big bowl. Next, you will add the chocolate flour into the bowl and mix with a spoon.
Step 3: Bake the Cake!
After the the cake is mixed, you will then preheat the oven at 350 degrees while you set the cake in a pan. The pan should be sprayed with vegetable oil spray and covered with a thin layer of white flour so the cake won't stick to the pan when it is finished. The cake mix should then cover the rest of the pan and be placed into the oven for 30-40 minutes, depending on how big the pan is or until the cake is fully baked. Check with a toothpick to see if time should be added.
Step 4: Crumble the Cake!
Once the cake is ready, let it cool down for 10-20 minutes. After that, tear the cake apart and crumble it in to crumbs in a big bowl with CLEAN HANDS. Next you will add 3 spoonfuls of chocolate frosting to the crumbs and mix it together. This is mixed so when the cake is made into balls it will act like glue keeping it together.
Step 5: The Balls Emerge!
Before making your little balls, have a tray covered in aluminum foil or a clean table ready to place your balls. Then create you balls at whatever size you like and place them on the tray.
Step 6: Cover Your Balls!
After your balls are created you will then coat them with melted chocolate. Place chocolate chips into a small bowl and microwave for a minute and 15 seconds. After stirring the melted chocolate, place a toothpick into one of the balls and place it in the bowl to cover them with chocolate. Once the ball is covered place it back on the same tray or table to cool down. Repeat for all the balls.
Step 7: Enjoy!
After that is completed you can decorated the balls or not either way they will taste amazing!
