Introduction: How to Make Cake Pops With Unique Flavors
I typically make my cake pops using the old school Bakerella method which includes a boxed cake mix and canned frosting. Unfortunately, there are only so many different flavors of premade cake mix and frosting available. That’s where Sarah of Miss CandiQuik comes in. With her blog post, Coffee Creamer Cake Pops, she opened my eyes to a whole new world of cake pop flavor possibilities.
Step 1: Make Your Cheesecake Flavored Cake
Today I will be sharing with you how to make cheesecake-flavored cake pops.
Start by baking a cake by following the directions on a box of classic white cake mix, with a couple of modifications. First, if the recipe calls for vegetable oil, use slightly less than the amount that is called for to keep your cake pops from being to oily. Second, add 10 drops of LorAnn's cheesecake flavor oil to the batter.
Step 2: Destroy Your Cheesecake Flavored Cake
After your baked cake has completely cooled, break off chunks of the cake into a food processor and run until all that is left is fine crumbs. If you prefer to skip the food processor, you can crumble up the cake by hand instead, but you may want to cut off any hard edges of the cake first.
Put your cake crumbs in a mixing bowl and add just enough cheesecake-flavored coffee creamer to make the mixture the consistency of clay. I used 4 teaspoons. Set the mixture in the fridge so that it is chilled before starting the next step.
Step 3: Make Your Cake Balls
Use your hands to roll the mixture into cake balls that are between 1 and 2 inches in diameter. I like to use a stainless steel coffee scoop to measure my cake pop mixture so that each cake ball is consistently the same size, 1.25 inches wide. Do your best to make the cake balls round and crack-free without driving yourself crazy. Always remember that your sanity is more important than cake pop perfection! Return the cake balls to the fridge to chill before moving onto the next step.
Step 4: Turn Your Cake Balls Into Cake Pops
Microwave vanilla candy melts in a bowl on low power for 30-seconds at a time. Stop and stir after each 30-second interval then repeat until the coating is completely melted. Do not overheat the candy melts or your coating will become lumpy. If the coating is too thick, add a small amount of vegetable oil or shortening to thin it out.
Mix in 5 drops of cheesecake flavor oil. Add candy coloring if you don’t want your coating to be white. Use only oil-based colorings designed for use with candy. Other types of coloring will turn your coating into a lumpy mess.
Dip the end of a lollipop stick into the melted coating and then into a cake ball, gently pushing until the stick is about half way through the cake ball. Complete this step for all of the balls then set them in the fridge until the coating has hardened and they are chilled.
Step 5: Decorate Your Cake Pops
If your candy coating has cooled or thickened, repeat the microwave heating process.
Dip each cake pop straight down into the coating until the cake ball is completely covered and sealed. If you need to angle the cake pop, gently tilt it in one direction and then another. Do not stir the coating with the cake pop or it may fall off of the stick. Remove the cake pop from the melted coating by pulling it straight up. Then, turn the cake pop at an angle and gently tap off any excess coating.
Add any sprinkles or decorations to your cake pops while the coating it still wet. Set them upright in a styrofoam block or cake pop stand until the coating has completely hardened before wrapping.
For more creative sweets made simple, visit sugarkissed.net or stay connected on Facebook, Twitter, or Pinterest.
