Introduction: How to Make Char Cloth With a Tuna Can
I sacrificed my kids clothes and a can of tuna to make some high quality fire starter! Here's how to make a great batch of Char-Cloth to add to your emergency kit.
www.thekingofrandom.com
Step 1: Watch the Video!
Step 2: What Is Char Cloth?
Char-Cloth is a fire starting tinder that has the ability to capture and hold a spark amazingly well, and for a considerable amount of time.
According to Wikipedia;
"Char cloth (also called charpaper) is a swatch of fabric made from vegetable fiber (such as linen, cotton or jute) that has been converted via pyrolysis into a slow-burning fuel of very low ignition temperature.
It is capable of being ignited by a single spark that can in turn be used to ignite a tinder bundle to start a fire.
It is sometimes manufactured at home for use as the initial tinder when cooking or camping and historically usually provided the "tinder" component of a tinderbox. It is often made by putting cloth into an almost airtight tin with a small hole in it, and cooking it in campfire coals until the smoking slows and the cloth is properly charred.
Charcloth ignites with even the smallest spark, and is therefore commonly used with a flint and steel."
I use it as my tinder of choice my acrylic fire piston.
Step 3: Materials You'll Need
This project can be done with items you probably already have around the house!
I also found that cotton balls work extremely well, and have become my new favorite!
- 1. Tuna Can
- 2. "Lid lifter" style can-opener
- 3. Nail, punch, or small screwdriver
- 4. Cotton fabric
Step 4: Cook the Cotton
To make the Char Cloth cooker, just follow these steps;
- If possible, use a "lid-lifter" style can-opener to open the can. This cuts the top off along the side of the can.
- Clean out your tuna can and make sure it's dry and free of contaminants
- Place 4-8 cotton balls inside the can (Or about 4 round pieces of cotton fabric from your T-shirt)
- Replace the lid and press it back into place. (Note: If you cut it with a "lid-lifter" style can opener it should press and hold together like it was meant to be!)
- Flip the can over, and use your punch to make a small hole in the "top" of the cooker
Step 5: Fire It Up!
The goal is to heat the container up over 400C, and this can be done in a variety of ways. For example;
You can tell the process is working because you'll see the gas venting through the hole in the top of the container. These gasses are flammable, and may ignite. Don't worry if they do because that's normal and just fine.
The cooking is done when the gas stops and the flame goes out.
Note: I've found that cooking them beyond the point where the gasses stop, and flame goes out, can negatively effect their performance, so take the container off the fire as soon as practical.
Next;
Note: The container is very hot, so use protection on your hands to avoid being burned while applying the foil.
- 1. Use solar power via your Solar Scorcher from another project
- 2. Place directly in an open flame
- 3. Any other outdoor method of inducing heat. (Outdoors because potentially harmful gasses will be released and can smell up your house)
Next;
- Place a layer of aluminum foil over the hole to prevent air from sucking back into the container.
- Let cool for about 5 minutes
Step 6: How Did It Turn Out?
When the container has cooled off completely, open it up and the first thing you'll hopefully see is that your white cotton fabric (or cotton balls) have turned completely black.
Note: If there are parts that are still white, or brown, it's not cooked completely and needed more time on the fire.
To test your batch of char-cloth, brush gently with an open flame. The cloth should capture the heat and form a small spark that will continue to smolder for an impressive amount of time. 1 cotton ball can last a couple of minutes.
By blowing air onto the spark, heat will transfer quickly and can engulf the entire cloth.
This is the great advantage of the cloth. It can deliver a lot of heat when you need it (by blowing on it), or just hold a spark for a couple of minutes while you're getting your tinder bundle ready.
Step 7: In Closing
Well there's how to make a batch of char-cloth using materials from around the house. It's great for emergencies, so go make a batch for your emergency kit right now!
Haven't see the video yet? You can still see it here!
If you like this project perhaps you'll like some of my others. Check them out at www.thekingofrandom.com
