Introduction: How to Make Grilled Cheese in the Toaster
Do you love grilled cheese? Who doesn’t? This classic life hack will have you enjoying a grilled cheese sandwich in less than 3 minutes using only your toaster.
Watch the Youtube video!
Step 1: Grab a Toaster and Turn It on Its Side.
Step 2: Grab Some Bread and Some Cheese.
Step 3: Add Cheese to One Slice of Bread.
Step 4: Put the Slices in the Toaster.
* The slice with the cheese on it needs to go in the bottom slot.
* The plain slice goes in the top slot.
Step 5: Click the Lever and Insert the Bread Slices.
Once the lever is clicked in, push the bread slices in a few inches until they have reached the back.
* Caution* Be quick with this step as the toaster is heating up and your fingers will briefly be inside the toaster.
Step 6: Place Your Plate in Front of the Toaster.
Place your plate in front of the toaster to catch your grilled cheese sandwich.
Enjoy watching the cheese melt on the bread.
Step 7: Wait for It...
Depending on your toaster setting, your grilled cheese sandwich should pop out in about 2 and a half to 3 minutes.
The top slice will land on top of the bottom slice and slide onto the plate.
To get a perfect fit of the two slices, you must try to push both slices as flush to the bottom of the toaster as possible during the toasting process. If the top slice is at all crooked, it will land that way when popped out, but it’s an easy quick fix if it does.
Step 8: BAM!
Step 9: Chow Time.
Hot and fresh grilled cheese in under 3 minutes!
Step 10: That’s the Stuff!
This quick trick was no substitute for pan flipped & buttered grilled cheese, but you can see that in a hurry it does the job very well!
Maybe next time I will butter the bread first and see what happens.
Thanks for checking out my instructable! Please connect with me on my other sites below.
https://www.youtube.com/channel/ShowandTellVideos
https://twitter.com/ShowandTellVids
Step 11: More How to Videos!
Thanks for checking out my instructable! Watch the Youtube video!
Subscribe on Youtube for more How To videos from Show and Tell.
