How to Make the StarJavelin Paper Airplane
Intro: How to Make the StarJavelin Paper Airplane
Fast, long range and small, the StarJavelin is a tiny drone-fighter paper airplane. The StarJavelin is meant to complement the StratoJavelin and SkyMosquito, two comparable designs.
The StarJavelin was the eventual result of an effort to develop an aircraft with a wing based on that of the Lancer, mated with the fuselage of the StratoJavelin for improved aerodynamics. In testing, that project's prototype showed some difficulties, and so the wing was modified with increased leading edge sweep. The StarJavelin was created with this change. Performance improved and the aircraft showed docile handling with the new, smaller wing. In further testing, the aircraft proved itself quite capable and was approved for publication.
TAA USAF Designation: D356-1
STEP 1: Materials
Required:
1 Piece of 8 by 10.5 inch graph paper
Scissors
Ruler
Tape
Pencil
Stapler
STEP 2: Begin Construction
Start construction of your StarJavelin by sketching out the design featured in the first picture. The graph paper this is made on should have one set of boxes folded in half at its crease. The fuselage is 10 boxes in length and has a counterweight of 3 by 2 boxes. One box from the rear of the fuselage, make a solid line along the graph line 0.5 boxes above the crease that stretches 2 boxes forward. Then 2 boxes inwards from the rear of the fuselage, make a dotted vertical line. The layout of the lines is complex, so it is easier to show than explain. Then cut it out.
After the fuselage is made, take another sheet of paper that is folded in half along the lines of boxes. Mark out the wing as shown (1 box of constant chord at the root, with leading and trailing edge swept portions beyond this box of 1 boxes of chord eliminated every 2 boxes of span). Then cut the wing out. Measure 2 boxes along the crease, measure two boxes upwards from one mark and make another point. Then draw a diagonal line connecting this new mark to the one further away. From the mark you just made, measure one box further away from the one now connected to the line and make a mark. Sketch a line between this mark and the other mark along the crease. Then cut the horizontal stabilizers out.
Solid lines indicate places to cut. Dotted lines indicate fold lines.
Note: 1 box = 0.25 inches
STEP 3: Making the Fuselage
Begin making your airframe's fuselage by cutting it out and folding the counterweight in. Next, cut along the solid horizontal line as shown. Once this is done, fold the vertical stabilizer forward along dotted vertical line and fold the landing gear and spars down. Then unfold. Once this is complete, tape where designated.
STEP 4: Applying the Wings and Horizontal Stabilizers; Stapling
Cut out your wings and lay them out flat. Align the fuselage over top so the spars align with the wing as shown. Then apply tape. Cut off any excess. Flip the aircraft over and apply tape to the leading edge of the wing above the leading edge root extensions.
Once you have finished with the wings, cut out your horizontal stabilizers and slide them through the slit in the fuselage you made earlier. When through, fold them up and apply tape to the underside; then fold down. Apply one staple in the area of the counterweight. This will have completed your aircraft.
STEP 5: Flight
Like the StratoJavelin, the StarJavelin is an easy to fly drone, and is a good choice for new aviators to work with after a few test flights. Launches should can be done at any attitude at a moderate to fast speed. Adding dihedral deflection and/or nose-up trim to the horizontal stabilizers may be necessary. Additional applicable surfaces include flaps, flaperons, slats, ailerons, elevators, spoilers, spoilerons, trimmable rudders and air brakes. Enjoy!
2 Comments
jwgottabass 9 years ago
Wow, terrific job. I got into paper airplanes for a short time; nothing at this level mind you. But I was turned off by the complexity and less than specific instructions that resulted in wasted time, effort and plenty of frustration with poor performance to boot. But these not only look amazing enough to try again, but you have done an excellent job with instructions that should make this fun and worth while. And I personally, rarely find the words worthwhile and paper airplane in the same sentence. Lol
MsSweetSatisfaction 9 years ago
That's an awesome little plane! Thanks for all the useful pictures, and for sharing!
