How to Make a $50 Pottery Wheel
Intro: How to Make a $50 Pottery Wheel
You can use a ceiling fan motor and a plastic bucket to make a pretty decent pottery wheel for under $50. The most expensive part is the ceiling fan, and you can pick those up, on sale, for $30, or at a garage sale for even less.
History: My kids were both into pottery, and really wanted a wheel. Decent wheels are pretty expensive, but luckily a friend of mine had a Clay Boss pottery wheel, and loaned it to us for a few weeks. We had a lot of fun with it, but alas, had to give it back. I recently picked up an old ceiling fan that one of my neighbors was throwing away, and I realized I could use the motor to make a pottery wheel, similar to the Clay Boss. Here is a link to my original inspiration:
http://www.clay-king.com/pottery_wheels/speedball_pottery_wheels/speedball_clay_boss_pottery_wheel.html
41 Comments
got2bskilled 10 years ago
HowToLou 10 years ago
Also, ceiling fans use induction motors, which are safer around water than standard motors, because they have no commutator and brushes that segment the electrical wiring. That is, induction motors have one continuous wire, through the entire motor, so the electricity always has a good path to ground. If you look closely, inside the back end of a running hair dryer, in a dark room, you will see that it occasionally generates tiny sparks, inside the motor. This is where electrical contact is being made and broken, hundreds of times per second. You will never see these sparks inside induction motors. Incidentally, this is also why induction motors are so quiet.
I will make two safety recommendations: 1 - Plug this wheel into a GFI outlet, such as in a kitchen or bathroom or basement for extra precaution. 2 - Drill a hole in the side of the bucket, 3 inches from the bottom, to provide an overflow, should the bucket ever start to fill up with water. This is unlikely, because it would take almost a gallon to get 3 inches in the bucket, and water should evaporate between uses.
I never considered fingers getting caught. I suppose that could happen with any pottery wheel, as they all have splash shields. In the video, my wheel was a little off center, after I mounted it. I fixed this by drawing a pencil line, at the very edge, while it was running, and then trimming to that line, with a saw. This consistent edge should reduce the risk of caught fingers, because there is nothing to "grab" you. You might also want to sand and round off the edges of the wheel, so they are even less likely to catch anything.
mr_oz 7 years ago
Quick question:
What power specifications does the motor u used has?
Thanks in advance!
cheers Massimo
RonW45 7 years ago
Emeraldharpist 8 years ago
Is there any instructable on how I would go about attaching a sewing machine pedal plus a variac (variable controller) to control the speed? I know nothing about electrics, so I don't even know the right words to search, and I want to make sure that I'm doing the right thing! Anyone know?
HowToLou 8 years ago
http://amzn.com/B000LJNJOE
This wheel runs at a good speed, if your hands are on the clay, but too fast, if not. Simply press on the pedal, when you are working, and let off otherwise.
mk00 8 years ago
Is there any way to control the speed of the wheel? Great instructable! :)
NylaC2 8 years ago
i am 12 years old and i am going to make this tomorrow and it looks like it works we will see tomorrow #loveit
cdstudioNH 8 years ago
brilliant!
Desert Rat 8 years ago
it was going great until I tried to pull the wires through to the other side and all 4 of them pulled loose from inside the motor. now what do I do?
it was going great until I tried to pull the wires through to the other side of the motor and three of them came loose from inside of the motor. Now what am I supposed to do?
АндрейА7 8 years ago
автор красавчик! весьма оригинальное техническое решение, приятно порадовал, спасибо.
Vickiboo120 8 years ago
FranciscoM17 8 years ago
rbusch 8 years ago
excellent idea and execution of the project! i might try this and see if i cant attach a foot pedal or dial for variable speed control. other then that looks fantastic! i have thought about building one before but never considered a ceiling fan motor.
pattiemelt 9 years ago
Great 'ible. I haven't thrown in years & have been trying to figure out how to build a 'portable' wheel that doesn't cost a fortune. This may be just what I need.
For foot pedals, you should be able to attach one with no problem. If you don't want to ruin your sewing machine pedal, you can buy them pretty cheap at places like Harbor Freight.
