Introduction: How to Make a Macro Lens
In this instructable I'll show you how to make a Macro lens. Macro lens's are used to take close up pictures of stuff. Most cameras (like mine) can't take a clear picture if the object is to close, this lens will help when taking really close up pictures. This is great for taking pictures for an instructable!
You'll Need:
- Some small Lens's (you can get these from Binoculars, Cheap rifle scopes or small magnify glasses, or pretty much anything)
- A Dremel
- A Razor
- Card Board, Wood
- Small Plastic bottle
You'll Need:
- A Dremel
- A Razor
- Card Board, Wood
Step 1: Different Lens's
There are two different lens's I'll show how to make. I'll show you how to make a cardboard one first.
To make the cardboard type, cut out a circle of card board that fits over your cameras lens, then drill or cut a hole in the card board and insert the lens, Your Done!! (with that type) you can use either duct tape or tacky to keep it on.
Step 2: 2nd Lens Type
This is a better model, but its a little harder to make. First, you'll have to find a plastic bottle that fits over the lens of your camera. Then, once you find a bottle bottom drill a hole the size of the lens and put the lens in the hole, now you have completed your lens.
Step 3: Attaching the Different Lenses
Here is how I attach the lenses, this will differ on what type of camera you have.
Step 4: Different Sizes
Different size lenses will result in different pictures, the small the lens the closer up pictures possible the bigger the lens not so close pictures possible
Step 5: Resulting Pictures
Here are some pictures I got.
Ask if you have any questions
Enjoy!!
Enjoy!!
