Introduction: How to Manually Merge Gmail Account With Apple Mail 2.0-3.x
This tutorial will instruct those with basic computer skills how to merge their Gmail account into Apple Mail 2.0-3.x in 10-15 minutes.
YOU WILL NEED:
-an Apple computer with Apple Mail 2.0-3.x
-an Internet connection.
-an existing Gmail account.
HOW TO CHECK IF YOU HAVE THE CORRECT VERSION OF APPLE MAIL (2.0):
1. Open the APPLE MAIL APPLICATION.
-The mail icon will be on your desktop. This looks like a postage stamp with an eagle on it.
-If you cannot find Apple Mail, search for the application using the magnifying glass on the top right corner.
2. Click MAIL on top left of the computer screen.
-A drop down menu will appear.
3. Select ABOUT MAIL from the drop down menu.
4. A pop up screen should come up stating what version of Apple Mail you have.
5. If you have Apple Mail 2.0or any Apple Mail 3.X , then you can manually follow this tutorial.
6. Exit out of all windows.
YOU WILL NEED:
Step 1:
Open your desired your Internet Browser (Safari, FireFox, Google Chrome, etc).
Step 2:
Go to www.gmail.com and sign into your account.
Step 3:
Click the GEAR IMAGE on the TOP RIGHT CORNER of the website.
- A drop down box of options will appear.
-Click MAIL SETTINGS.
Step 4:
Click the tab Forwarding and POP/IMAP.
Step 5:
Click the bubble ENABLE POP FOR ALL MAIL.
Step 6:
Click SAVE CHANGES at the bottom of the page.
Step 7:
Exit out of the Internet Browser.
Step 8:
Open the APPLE MAIL APPLICATION .
Step 9:
Click Mail on the TOP LEFT CORNER of your screen.
-Click PREFERENCES.
-Click PREFERENCES.
Step 10:
Click the tab Accounts.
-Click the PLUS SIGN [+] AT THE BOTTOM LEFT OF THE WINDOW to create an account.
Step 11:
Enter all information correctly on the window titled “Add Account”:
a. Your Full Name.
b. Email Address: (the Gmail address you are linking)
c. Password: (for the Gmail account)
a. Your Full Name.
Step 12:
UNCHECK AUTOMATICALLY SET UP ACCOUNT.
Step 13:
Check all information is correct and click CONTINUE.
Step 14: Incoming Mail Server
Enter and check all information:
a. Account type: POP.
b. Description: YOU DECIDE. EX: GMAIL ACCOUNT.
c. Incoming mail server: POP.GMAIL.COM
d. Username: ENTER GMAIL USERNAME.
* If your email address is: example@gmail.com then your user name would be: example.
e. Password: YOUR PASSWORD FOR THIS ACCOUNT.
Step 15:
Click CONTINUE.
**If the “Incoming Mail Security” window appears, makes sure that “SSL” is checked, and the Authentication box is set to “Password.”** After, Click CONTINUE.**
Step 16: Outgoing Mail Server
a. Description: LEAVE BLANK.
b. Outgoing Mail Server: SMTP.GMAIL.COM.
-Leave ‘USE ONLY THIS SERVER’ unchecked.
c. Check USE AUTHENTICATION.
- Username: ENTER GMAIL USERNAME.
*Email: example@gmail.com
*Username: EXAMPLE
d. Password: ENTER GMAIL PASSWORD FOR THIS ACCOUNT.
*Username: EXAMPLE
Step 17:
Click CONTINUE.
**If the “Outgoing Mail Security” window appears, makes sure that “SSL” is checked, and the Authentication box is set to “Password.” ** After, Click CONTINUE**
Step 18:
Check the "Account Summary" is correct:
a. Incoming Mail Server: POP.GMAIL.COM
*SSL: ON.
b. Outgoing mail server: SMTP.GMAIL.COM
*SSL: ON.
c. Check TAKE ACCOUNT ONLINE.
*SSL: ON.
*SSL: ON.
Step 19:
Click CREATE. The account should now be set up.
Step 20:
Exit out of ACCOUNTS and PREFERENCES windows and return to the APPLE MAIL APPLICATION.
Step 21: How to Use Apple Mail
Click MAIL.
-Select PREFERENCES.
Step 22:
Go to ACCOUNTS TAB.
Step 23:
Select the ACCOUNT you just configured on the left side.
Step 24:
Check ACCOUNT INFORMATION.
Step 25:
Click ADVANCED TAB.
Step 26:
Check PORT NUMBER:
-Port: 993.
-Port: 993.
Step 27:
Make sure ‘USE SSL’ is checked.
Step 28:
Close PREFERENCES WINDOW and return to the APPLE MAIL application.
Step 29:
To RECEIVE MAIL:
-Click GET MAIL on the top left corner of the application.
Step 30:
To SEND MAIL:
-Click NEW MESSAGE in the middle of the application.
Step 31: To Add an Additional Gmail Account
Return to PREFERENCES.
Step 32: To Add Another Account
Click ACCOUNT.
a. Click the PLUS SIGN (+) on the bottom left corner.
b. Repeat steps 11-28.
