How To: Miter Saw Shadow Line
28,642
236
21
Introduction: How To: Miter Saw Shadow Line
About: My name is Chris, and I make things. Follow my makerspace on Instagram @makeeverythingshop And check out my new Youtube page www.youtube.com/makeeverything
Today iI’m going to be adding this inexpensive LED light to the saw hood on my miter saw. This led light will shine directly down over the blade and cast a shadow onto the workpiece.
Check out the video tutorial here:
Dive into this intractable for a detailed write up of the process.
This type of light system is becoming a new standard on miter saws, but this Bosch GCM12SD saw that I am using doesn’t have that option. Companies like Dewalt, ridgid, and Milwaukee have put this light system on their newer models. The real key to this LED light working properly is that it is centered over the blade, this is easy to do, and easy to verify before you attach anything to the saw. The other part of this that is crucial is that your particular saw guard has to have enough room to clear the LED light as it comes up over the saw hood.
LED Light I used: https://www.amazon.com/gp/product/B005UF8P52/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Step 1: Disassemble the LED
The led light I'm using is a very simple “sewing light” from amazon (link: ) . I like this light because it has a little magnetic enclosure that houses the control board and a switch, it also has a very slim plug and not one of those big black box plugs. To take it apart i gave it a little tap with the back of a screwdriver and it popped open. Once its apart I pulled the flexible gooseneck from the led out of the housing so I could remove the components from the enclosure completely.
Step 2: Remove the Blade Guard
On this Bosch saw the blade guard is very easy to remove, two screws near the arbor, and one large screw near the pivot point. Once its removed I also remove a small plastic piece near the end of the saw hood. This piece will be modified and re used later to hold the new LED light in place.
Step 3: Test Fitting the LED
Whats nice about this project is that its really easy to see that its going to work right away. Once the blade guard and plastic piece are removed I take a bit of gaffers tape and tape the LED light to the top of the saw hood. I then move the blade up and down a few time over a sample piece of wood and make sure I'm getting an accurate shadow line.
Step 4: Extending the Wires
This particular saw uses a 12” blade, so the top of the saw hood is very large. Because of that I need to extend the wires that go from the LED light to the control board/enclosure. If you do not extend the wires the blade guard will hit the enclosure when the saw head is brought down to make a cut. To do this I will use 22 gauge speaker wire and some solder. To begin, I desolder the led light from the control board by heating up the two points of contact. I then strip back the wires and solder a 7” extension to both leads. There is a - an a + side of the control board and you need to make a note as to which color wire out of the LED goes to which terminal.
Step 5: Securing the Connections
Once the two wires are soldered I will use heat shrink tape to insulate the bare wire and enclose the two separate wires giving it a nice clean look.
Step 6: Re Attaching to the Control Board
Now that I have a securely extended LED power wire I will wonder it back to the control board at the original + and - terminals that i removed it from. Twist the wires tight and pass them back through the holes. Add a little bit of solder and test to make sure the light still functions. It goes without saying that the light should have been UNPLUGGED during the last few steps and be extra careful when plugging it back in while the enclosure is open.
YOU CAN AND WILL GET SHOCKED AND POTENTIALLY SHORT OUT THE CONTROL BOARD IF YOU TOUCH BARE WIRES WHILE IT IS PLUGGED IN. BE CAREFUL.
Step 7: Reassemble and Test Fit Again
Now that everything wired back up put all the components back in the enclosure and move back over to the saw. Using some tape I put the LED light back on the saw hood and just double check that everything is working properly.
Step 8: Mount the LED Light (modify the Original Plastic Piece)
Here is where that little black plastic piece comes back into play. The way its shaped is nearly perfect to house the new LED light. I will draw a general approximation of the shape and use a Dremel with a cut off wheel to remove material from the plastic piece. It takes a few attempts at fitting and grinding to get it just right.
Once it all fits together I reattached the plastic piece with the LED inside of it using 2 of the 4 screws I had removed. You will see it sits a little proud of the front once its seemed but its very sturdy even with just 2 screws. (keep the other two screws just in case)
Step 9: Attach the LED Cable
Using a few dabs of hot glue I attach the new LED cable to the top of the blade hood. I use hot glue because it will not harm the paint on the saw, but is very sturdy. It will allow me to take this light off easily if I want, and will be secure.
Step 10: Re-attach the Blade Guard
Now you can put your blade guard back on, blade guards are important so make sure this is done properly! Keep yourself safe!
Step 11: Mount the Control Box/switch, Power It Up
This particular light has a magnetic base which is great for this application. The Bosch saw has a steel support arm on the blade guard so I just magnet the control box to the back side of the steel arm.
This keeps it out of the way when cutting material but its easily within arms reach when I want to turn it on or off. To power the LED light I purchased a 3 way splitter from my local hardware store so I only need 1 plug on an extension cord to power the whole system.
Step 12: Test It Out! Become a Miter Saw Master!
You did it, your saw has been upgraded in a way that will forever change woodworking! Seriously though, once you use a shadow line on a saw you'll wonder how you ever cut wood without it. The level of accuracy you can achieve with a shadow line like this is unparalleled, even with lasers. The beauty of this install is that its basically self calibrating. If you have a thin kerf saw blade, the shadow will be thin, a thick kerf saw blade, the shadow will be thick. I hope this intractable will encourage people to try this modification. I have done this to a few saws now and every time I use a saw that DOESN’T have a shadow line I feel like a part of me is missing. If you have any questions, please leave them in the comments and I will be glad to answer. Don't forget to check out my youtube channel for more stuff like this and interesting projects!.
Makerspace Contest 2017
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    21 Comments
    TimK162
    TimK162
    5 years ago
    Good idea!
    One thing, there is a typo near the beginning. You have "intractable" instead of "instructable".
    Cliffystones
    Cliffystones
    Reply 5 years ago
    He repeats it near the end as well. I just wanted to thank him for something I'll be needing in the not-to-distant future, and for the laugh I got from the typo :) I have a Harbor Freight 12" compound miter saw that i use on occasion, but the laser it has leaves much to be desired.
    Really though!, who wants to build something that is "difficult or impossible to manage, manipulate, or control." (definition of intractable). Not trying to give you grief M E, just a little good-natured ribbing from an old fart.
    Make Everything
    Make Everything
    Reply 5 years ago
    haha! I will never win any awards for spelling or grammar but I can build a thing or two! If you have any issues when you set yours up let me know and ill try and help!
    Yonatan24
    Yonatan24
    Reply 5 years ago
    You won't believe how often the word Intractable/Instructables/'Ible gets spelled incorrectly :)
    davivand
    davivand
    5 years ago
    awesome
    big dawg1
    big dawg1
    5 years ago
    It's a great idea, however, my 3 saws have blade guards that are much closer to the housing than your Bosch so I'm afraid this will not work for many saws.
    tytower
    tytower
    5 years ago
    Hmm good idea . perhaps the square or round magnets you buy might be used and epoxied to the LED and control so no hot glue needed.
    dogs4kids
    dogs4kids
    Reply 5 years ago
    He said he used hot glue so it was removable. Epoxy is an option, but it would make it permanent.
    Jdsardone
    Jdsardone
    5 years ago
    this is great, I have a cheap headlamp with a finicky battery pack, which may be getting a new life as one of these.
    charlessenf-gm
    charlessenf-gm
    5 years ago
    Look at LED strip light kits. Smaller, bendable stips of light you can cut to length, wire to the driver/power on the existing LED (likely uses same voltage - test first) with a three-way switch to allow choosing LASER line or Shadow line while powering everything form the saw - eliminating need for triple tap and extra AC feed line.
    charlessenf-gm
    charlessenf-gm
    5 years ago
    Wire the thing to the saw so it is powered by the feed to the saw - eliminating the need for the triple tap and second ac feed line.
    I would think the LED strip lights would serve as well with far less bulk.
    MisterHighway
    MisterHighway
    5 years ago
    Thanks! This was a great Instructable! I was able to find those lights even cheaper on eBay under the search string AC 110V-220V 30 LED Lamp Beads Sewing Machine Light Magnetic Base With Switch for about 4-5 bux. I just bought one for my saw, my buddies saw, and a one just for my nightstand lol. Great idea and thanks again!
    Wingloader
    Wingloader
    5 years ago
    Oh yeah, you got my vote too.
    Wingloader
    Wingloader
    5 years ago
    This is awesome. I'm going to buy one of those lights right away. Then it will sit on my workbench for six months while I procrastinate implementing this awesome invention :-)
    I am in the middle of a project right now using a miter saw frequently. This would save so much guesswork
    JoeyyBoyy
    JoeyyBoyy
    5 years ago
    Great idea and video! Any ideas on how to extend this idea to a table saw?
    deluges
    deluges
    5 years ago
    Darn smart. Just gotta buy a saw now. You got my vote
    impola7
    impola7
    5 years ago
    Two points for this one. Good job. Better than a laser.
    TimG139
    TimG139
    5 years ago
    Nice one!!
    gm280
    gm280
    5 years ago
    Interesting concept. How does it work with larger wood? I cut 2x4's, 2x6's, 2x8's, 4x4's and even 4x6's some times. Does the shadow stay clean and focused with different woods or does the shadow edges get fuzzy on the larger woods?
